Thread: TPMS....best place to get a sensor?
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Angry TPMS....best place to get a sensor?
    This a good reason NOT to use alloy valve caps on your tyre valves..
    I try to keep them lubed up so they dont cease on but tonight when removing one (that had ceased)..SNAP! It has broken the the threaded part of the valve stem off, leaving the valve needle sticking out, Now if thats not bad enough i have TPMS so i THINK (could be wrong) i have to replace the full thing...sensor as well as they are one unit,
    Could someone please clarify this for me? and where is the best place to get a TPMS wheel sensor? Does it need to be tech 2'd when new?
    Im a bit cheesed off to say the least!
    Full Member Big Sig's Avatar
    Andy L got some from somewhere cheaper than the dealers. Send him a PM
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just seen your location. Have you been to Autovaux, all there gen VX stuff is cheaper than VX themselves. The part wont be listed on there site but they'll still get it mate.
    If you cant get there just drop Kieron an email on kieron@autovaux.co.uk
    Autovaux
    Unit 44 Monckton Road Industrial Estate
    Denby Dale Road
    Wakefield
    West Yorkshire
    WF2 7AL
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Will dig out the place i use in the morning, bout half the price of Vx and they are the same ones Vx use.
    Jan 2008
    Pontefract
    Cheers Rushy and Plasma. Do you know if it will require a Tech 2 session to get it to work or are they plug n play?
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    http://www.tyre-equipment.co.uk/acat...or_Valves.html
    http://www.schrader.fr/fr/Pdf/4_TABLEAUX_2008-11.pdf
    Probably need a tech2 session to get it to start to relearn the new senso
    Jan 2008
    Pontefract
    Quote Originally Posted by plasma View Post
    Thanks for the links, i have saved them for future reference!
    However upon inspection in daylight, it would appear the thread part had sheared off about half way down, all i had to do was get the rest out from the alloy cap and stick it back together, which i did! I used a very expensive chemical metal which has done the trick.......now to go and buy some plastic valve covers!
  1. Best Place For New MAF Sensor.
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 22:33
  2. Tpms
    By R2XPT in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 14:47
  3. Facelift TPMS sensor locations?
    By Simon_Fuller in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2012, 04:50
  4. From which car is this TPMS sensor?
    By andrius.kr in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 16:56
  5. TPMS or DDS????
    By deejer73 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 18:16
