Thread: Interior light keeps coming on.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Interior light keeps coming on.
    On several occassions whilst driving, my interior light comes on for a split second then goes off. Usually happens going over poorly surface roads as the body shell flexes.
    Sometimes, just as I've jumped in the car, the interior light stays on but a good slam of the driver's door usually sorts it but then we're back to the above intermittent problem as above.
    I've greased the stiker catch and door lock mechanism and adjusted the striker so the door closes really tightly. Also no warning light to say that any doors aren't closed properly.
    Question is, what part of the door lock assembly makes the circuit so the light goes out so that I can investigate further?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Have you donr all the doors and boot?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Yep. Greased all lock bits that you can see in the door without ripping the door cards out and adjusted all strikers. Did think at one stage that it was the rear n/s door but now, when the light stays on, slamming the drivers door at least puts the light out til I move off. I had a new drivers door lock motor fitted a few months ago but I think it's something to do with how the circuit is made, ie. lock mechanism contacting with striker pin?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Doesn't the door open light come on the dash? I'm thinking it may be the ignition key barrel at fault if there is no door open light. It is designed so that when the key is removed from the ignition the int. light comes on.
  1. ABS light coming on
    By snake35 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 10:59
  2. TC light coming on (sometimes)
    By gibbon7000 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd January 2012, 17:33
  3. Help.battery light keeps coming on!!!
    By felixx in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2011, 20:29
  4. Light keeps coming on
    By harley270906 in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2010, 19:43
  5. interior light not coming on when door opens
    By oxenburger in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 22:11
vectra c interior light stays on
