Thread: Flush or No Flush(2.2Dti)
    South London
    Default Flush or No Flush(2.2Dti)
    Hi
    Car is now 51/2 years old(04 reg).
    It has always been filled with 5W30 fully synthetic oil. For the first two years the oil was changed every year. since then it has been changed at 6month intervals. The current mileage is 44,500. Mostly used on very short journeys.
    I am now about to change the oil again and I am undecided whether to this time use Wynns engine flush.
    What would you do?
    I have a tin of unopened engine flush that is about two years old, would it still be okay?
    Full Member Big Sig's Avatar
    TBH it may dislodge some sludge that may cause problems. Personally, as you change the oil so often, I wouldn't bother.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    as said i would only flush if it's been flushed on a regular basis you don't want to dislodge something
    Mileage : 000
    Not a good idea to use a flushing oil.
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    do what i did. whip the sump off once youve emptied it and give it a REALLY good clean. i used Gunk then left it for half an hour then tipped it in the a waste can then got a scotch brite and cleaned the residue out with just diluted gunk. then dry it out really well refit it and fill it up.
    its a DAMN dirty job mind you. but ull be amazed how much rubbish is in there! well mine was 5 years old at the time. i figured id do it myself than chuck some chemicals i wassnt sure about into an expensive engine.
    Plus doing it manually means you can ensure that ALL the sludge has been removed. the oil in mine stayed oil coloured for about 3 months with out going black.
    im sure someone will say never to do this in a min and give a mirriad of reasons. but its done no ill effect to mine (2.0DTi)
  1. coolant flush, and gearbox oil 2.2dti help
    By paul.sessions in forum Engine & Drivetrain
    Last Post: 2nd April 2011, 00:13
  2. will i flush her?
    By twaiter in forum Engine & Drivetrain
    Last Post: 19th March 2010, 22:32
  3. to flush or not to flush
    By aerodynamic18 in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:27
  4. to flush or not to flush
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2008, 22:56
  5. Flush fit sub
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2005, 23:05
