Thread: Replacing NCDC 2013
    Regular Member Padster72's Avatar
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Default Replacing NCDC 2013
    I am think about replacing the OEM NCDC2013 in my GSI, but not sure what to get, and if I am able to retain the BC functions, and display.
    I'm not too worried about Nav as I use a Garmin unit when I need it, but do what iPhone compatibilty.
    Any ideas what to get, and how to retain the BC functions and display?
    E-mail big Phil as I know he replaced the same unit as yours
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Dont think you will keep BC functions as the NCDC radio has the button to access it,the only thing you will have is on the display if you cahnge to another HU is the time and date and what ever BC function you have set it to
    You might be able to fit a wiperstalk with BC function and get it activated that way.... HTH
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    The BC function can be controlled from the steering wheel, so I was hoping to be able to retain it, and control from there. Does any opne now if this can be done?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I thought to access BC you pressed BC button on stereo ? you cant access it from controls
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you can access your BC with the steeringwheel.. but only if you have the ncdc/cd70 in place. or maby if you get the steeringwheel adaptor with your new aftermarket radio so you also can control that.
  1. Replacing A NCDC 2013 Radio with a 'Normal' double DIN Headunit?
    By StreetDragster in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2013, 21:41
  2. Ncdc 2013
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 22nd August 2012, 12:27
  3. Ncdc 2013
    By Shaun_inuk in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2012, 15:32
  4. Any one got sat nav cd for NCDC 2013
    By driveryte in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2010, 18:36
