Results 1 to 10 of 18
Thread: Magnetic Oil Drain Plug
    Default Magnetic Oil Drain Plug
    I had one of these fitted to my old Mini. Fair enough it was an engine/gearbox combo but I had a 'Magnetic Oil Drain Plug' fitted & boy did it attract those little bits. My question is does anyone have one fitted to their Vectra, if so how effective is it & is it worth the investment.
    Check out this OilDrainPlugLink ...........
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    I've got one on my motorbike and it is amazing how many shards of metal are stuck to it at oil change time
    Used on aircraft engines for the very same reason...
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    they dont do one fo a vectra tho do they?
    Quote Originally Posted by aerodynamic18 View Post
    Click on the link & look under 'Sump Plug’ hth …………..
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    good find there! I will if someone else does .. well.. when it comes around to service time anyways. Got to be better than shards floating about on in ur crank shaft.
    Do they do OHM results on civi cars? I know in the army we get to collect OHM samples (oil health monitoring) which can pick up even the slightest bit of trouble with the main workings of your engine by the extra bits in ur oil... be handy if you could do this with your normal car too?
    Plymouth
    Tadders.... ur 2 weeks to late for me!! Just had it serviced and i would of like one of those in mine 'just incase'
    Quote Originally Posted by Diet1985 View Post
    Thinking of getting one for christmas .....................
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    http://www.magneticoildrainplugs.co.uk/vauxhall.html ?
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    Used to have one fitted to my golf gti turbo. Bought it from Awesome GTI in manchester and it came with about 10 bronze washers, They are really good at keeping the nasty bits out of the engine.
  1. f40 drain plug access
    By justin32 in forum Engine & Drivetrain
    Last Post: 26th November 2011, 15:10
  2. Oil Drain Plug Vectra C 2l Dti
    By dc6839 in forum Engine & Drivetrain
    Last Post: 6th July 2011, 08:17
  3. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  4. Magnetic Sump Plug
    By Z28 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 21:37
  5. oil drain plug ?
    By dmoffat in forum Engine & Drivetrain
    Last Post: 17th June 2008, 10:27
vectra c magnetic oil
