Thread: DPF
    Birmingham
    Default DPF
    Right, another thicko question.
    DPF is the Diesel Particulate Filter....RIGHT?
    Where is it?
    What is its fucntion?
    Can this get blocked and how?
    How is it best to clean this or un-clog it?
    I have just read about this on another post and am thinking could this cause some perfromance lag?
    Thanks guys.
    Sorry, car is 1.9 CDTI SRI 6-Speed Manual.
    Bye bye Vec B
    - Hello Siggy!
    Wales, UK
    Im not sure, think a DPF is only found on auto's - Whats yours ?
    I understand it has a certain cycle, in which it self-cleans. During this period, the car is less
    responsive....
    Correct me if im wrong !!!
    Birmingham
    Bye bye Vec B
    - Hello Siggy!
    Wales, UK
    Oh, i may be wrong but im prety sure the DPF is only on autos. Believe it will regen itself around 700 miles or something...
    http://www.vectra-c.com/forum/showthread.php?t=82966
    Have a read of that, just popped up on new posts lol !!
    Birmingham
    I were just reading that too! !
    Bye bye Vec B
    - Hello Siggy!
    Regular Member jun's Avatar
    burton-on-trent
    Mines a manual and my DBF is blocked big time ive only just replaced it.
    and now it wont if start up it now stuck at vauxhall
    The only way i no to unblock it is to take the filter out of it.
    Full Member Big Sig's Avatar
    Its not only on autos but not sure which manuals have it. It s located somewhere in the middle section of the exhaust, looks like a silencer but with a few pipes going to it. It can be forced into a regen via tech 2 or go on a long drive on the motorway, although it could take sometime before it regens.
    i am sure someone on here managed to take it off, knock the middle out of it, do something with the pipes and away he went.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    it's a bit of a job,seperate diffpressure linesfrom diesel particulate filter,remove temperature sensor(on the underside of unit)and unsrew fixing nut,remove centre exhaust system bracket,remove centre exhaust pipe with dpf.remove dpf from centre exhaust.as said a bit of a job!
