Thread: xenon headlights self leveling
    Feb 2007
    london
    Default xenon headlights self leveling
    my vectra 1.8 2006 facelift has xenon lamps which go through a self leveling routine when the engine starts and the lights are on.
    During this process only the left light goes up and down and then balances middway, the right one just makes a very small up and down motion , imagine that something is blocking it from moving and stops without going up and down.I t also shines further up from the left one , i figure that is why other drivers are flashing their lights to me.
    Any hints,
    Anybody with xenon headlights , please check and see the lights behaviour during the self leveling procees when you turn them on . Are they both going up down the same distance?
    Thanks in advance
    Mar 2007
    North East
    If there was something wrong I thought you got a light on the dash ? It's in the manual somewhere.
    Might be worth getting the beam aim etc checked just to be on the safe side.
    I've found I got flashed regularly with my xenons, not quite as much in the vec as I have been with the Insignia though. I put it down to the fact that they are generally much brighter and people think you have your high beam on.
    Full Member Big Sig's Avatar
    No need to post it TWICE
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    My pre-face does the same movement on both lights. Have you checked visually how the lights are levelled? If they both are levelled correct when you use the lights, it should be OK then? If there was/is a problem, you should get warned by a small yellow warningsign at the right side of the speedo-clock, the sign looks like a headlight and it flashes. Ive seen it a few times on mine, but cannot find any fault, and it dissapear if I turn off and on the engine.
    Bent, my name is Bent
    Mods: I polished it in september...
  1. vectra c Xenon Leveling sensors (rear)
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2009, 19:36
  2. Std Xenon Leveling
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2009, 20:48
  3. Xenon Auto leveling problem
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2008, 19:03
vectra c headlights not self leveling
