Thread: CDR2005 + Handsfree
    Aug 2009
    Nr Ipswich
    Wink CDR2005 + Handsfree
    I am looking at getting the bury CC9060 h/f kit, which I have seen a few other members have.
    I have the CDR2005 Radio in a 2002 Vectra LS, so it has the ISO connectors. Should I just connect the bury kit using the iso's or is there another method (think I might read that you route it through the radio).
    From what I understand there may be a connector lurking behind the glove box, going to have a look at that tommorrow.
    I had a look around and most of the posts I found were relating to the newer units with the quadlock connector.
    Apoligies if I have missed one though!
    BTW I must say what a great forum this is, only been here since Monday when I picked my Vectra up!!
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    I have had a look at the instructions on the Bury website for the CC9060 and it all seems pretty straight forward using the switch box AC5120 and the ISO connection. Just make sure you check the connection of both DC Power Supply and Ignition are correct as per the instructions. You may also need and adaptor for the Vx wiring which should be available from most Bury stockists.
    See if it fits, check the power on pins 4 and 7 of the ISO and if require then seek the approriate adapter if required.
    All the info you need and how to update your Bury is here LINKY!
    Done!
    Bri.
    Aug 2009
    Nr Ipswich
    Cheers, ordered it last nght, so just got to wait for it to arrive!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    You could also choose to tap into the VDA plug thats taped up near the besides the glovebox.
    This would fit straight on that.. http://www.bury.com/en/accessories/v...pterkabel.html
  1. handsfree kit
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 22:10
  2. mr handsfree car kit.
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 22:59
  3. Handsfree Car Kit
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2009, 09:07
  4. Handsfree Kit..
    By teilo in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 23:23
  5. help with handsfree req
    By dukedog in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2007, 23:08
