Results 1 to 10 of 13
Thread: EGR update - solutions
    Jul 2009
    north east
    Default EGR update - solutions
    now then
    following previos posts on a fault with my 150 cdti, this is the latest.
    the car stutters/hesitates/judders at a different point in the revs. its mainly around 1500 rmp but as the fault got worse as did the range in which the fault appeared. now following advice on here and elsewhere i cleaned the EGR valve, better at first but then the same, and now replaced the EGR valve, lots better and only done 20 miles since replaced, but the fault is definatly still there. only slightly but never the less it's still there.
    what now? someone metioned problems with torque bearings, possible or not? also the fault has started to affect the turbo. as the fault gets worse the more it affects it. it comes in later and the overall performance of the cars drops.
    help before i put a match to it!
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    3rd injector ?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    another 150 playing up....god bless the 8v
    3rd injector loom m8.
    Jul 2009
    north east
    3rd injector ? what does it do and can i replace it myself? any more info would be great?
    Aug 2009
    Havant
    Jenko,
    The connector cable is dodgy, that's all.
    Parts from VX should cost £12. All you need is to be competent with a soldering iron.
    how2 below
    http://www.vectra-c.com/forum/showthread.php?t=73584
    Jul 2009
    county down
    Default 3rd injector
    get VX garage to do it. I don't have a soldering iron and never will !
    Jul 2009
    north east
    read the how 2, thanks
    what is it doing? why is it broke and why the 3rd injector? surely any of the cables could be broke?
    Birmingham
    to the "we own a CDTI 150 with a problem that no one can fix" club mate!!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member nigec's Avatar
    barnsley
    Quote Originally Posted by vaux-man-g View Post
    To the "we own a cdti 150 with a Problem that no one can fix" club mate!!
    lol !!
    Aug 2009
    Havant
    why injector 3? heaven only knows. All the connectors look identical to me but it's only ever number 3 that goes as far as I can tell.
    I think its a case of heat from engine etc causing the plastic of the connector to break or whatever and the subsequent exposure of the electrical contacts within to elements causes corrosion and a lack of conductivity. That might well be a load of bunk but I cannot think of any other reason for it!
  1. Mobile Phone Solutions
    By hodge725 in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2012, 15:21
  2. DPF quick fixes, and permanent solutions
    By fixitsan in forum Engine & Drivetrain
    Last Post: 24th November 2012, 12:56
  3. Solutions for connecting an ipod
    By Dan70 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2010, 20:48
  4. Ipod connection solutions
    By Misty Design in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2008, 07:09
  5. Limp mode after tuning box install, any solutions?
    By kktdragon in forum Engine & Drivetrain
    Last Post: 8th July 2008, 21:31
