Thread: Loss of instruments
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default Loss of instruments
    Had a problem today and any advise would be great.
    Had driven for about 2 miles, came to a roundabout everything fine.
    Pulled away and after 100 yards noticed all gauges were on ZERO.
    Car was still accelerating ok. Put indicator on to pull into layby, heard indicator flasher ok but no warning light on dash, then flashed headlights to check-could see lights working but again no dash warning light.
    Pulled over turned off-restarted ok with all gauges ok and lights working.
    Any ideas-sorry for the long story but have tried to explain
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    sounds like a software glitch...
    all the systems are controlled by computerised signals from the can-bus.
    sounds like you did the car version of a computer cold-start / re-boot.
    If nothing else happens then fair enough, however if it re-occurs then it could be a program fault...
    If it returns and stays faulty then it could be a loose connector or corrosion in a plug..but where to start....possible water ingress through the scuttle panel drain points etc or near the pollen filter housing.
    Plugs are quite well made and don't separate that easily, and so the possibility of dirty corroded connections should be considered.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Its one of two things. CIM module, £350+ dealer fix only or dirty ABS plug, free with some contact cleaner.
    VIP-Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    A similar thing happened to me.
    Have a look at the thread I started at the time. LINKY!
    Bri.
    Today!! The new tomorrow, live the NOW!!
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    thanx Bri will give it a try later, although never had any warning light at all after restarting everything was fine-no EML on
    Jul 2009
    cambridge
    Default loss of dashboard instruments
    Hi,
    I have been experiencing the same problem, however when i put the hazards on, the fault disappears - is this likely to be the expensive option to fix?
    Jason
    Regular Member colalowe's Avatar
    in the North
    Just had this same problem tonight, having travelled to a friends and parked, no problem. When I returned the door light stayed on, I checked all the doors and initially thought it was a faulty door sensor.
    Started to drive and noticed that nothing on the instrument display was working apart from the constant red door light.
    Got home and checked the fuses, all were ok however I noticed that when I removed/replaced the Instrument display fuse (no 17 I think,) the instrument display reset and now works fine.
    The car is still in its warranty, should I get Vx to check it out??
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Quote Originally Posted by colalowe View Post
    Yes. The problem may manifest itself into something more serious and costly.
    Ashington, Northumberland
    Follow Rushys advice because one of those two things will cause those exact symptoms. The ABS plug is an easy DIY job, as Rushy said though, the CIM module will be a bit of a killer. It'll be one or the other
    Jun 2007
    leeds
    hi m8 mines doing the same all neddles at zero sometimes windscreen wipers come on on there own
    no indicaters/cruise control
    all lights working and drives ok
    ive noticed has well on cold starts early morning i get 50 yards up the road and for a mlli second theres a click and everything shuts down and fires up as normal
    would like to know if the original poster got it fixed and what the problem was, before i ring vauxhall up and spent £440
    cheers all
    ps looked a the abs plug its clean as a whistle
  1. Instruments all dead.?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2010, 20:52
  2. Replacement instruments .
    By Suffolk Boy in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2009, 20:54
  3. What instruments....
    By lofty in forum The 'Off Topic' room
    Last Post: 5th November 2008, 04:09
  4. Instruments problems!!
    By andy1103 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th June 2008, 21:09
  5. No Instruments or Radio?
    By pauls898 in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2007, 20:17
