Thread: Vectra 2.2 Pre Cat and centre box
    Jul 2009
    wishaw
    Default Vectra 2.2 Pre Cat and centre box
    Hi all does the 2.2i Direct have a precat installed and can it be removed and a straight pipe put in place? Also im planning on removing the centre box and replacing with a straight pipe is this also ok to do and does it make the car sound better as the standard exhaust is quite and would like more noise without a big cost of replacing full system?
    norn iron
    i think the direct version has the cat as part of the manifold, no pre cat like older 2.2 engines.
    was thinking about your straight through middle section, sportex do one for the vec although it is about 90 quid which i thought was a bit expensive for a piece of exhaust pipe with no boxes on it!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    As deg said mate, all 2.2's in the vec have the main and only cat in the manifold. If you want to mess with cats on 2.2 Vec C's you need an aftermarket manifold or vec B manifold, get a custom down pipe and flexi the put a sports cat underneath.
    Jul 2009
    wishaw
    think ill just leave the cat alone and replace the middle section and box with a straight pipe.
  1. vectra c sri rear centre headrests....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2009, 07:14
  2. Vectra centre vents
    By jamesr in forum Parts for sale
    Last Post: 29th March 2007, 20:29
