Results 1 to 10 of 14
Thread: Track Use Tyre Pressures and Tyre Temperatures
    spoons
    Guest
    Default Track Use Tyre Pressures and Tyre Temperatures
    I posted a thread on the VXR forum, but I though you guys may find this information useful as well..
    I'm running Goodyear Eagle F1 Aysemmetric 235/40/18 tyres on the Vectra VXR and will be fitting a Tyre Pressure Monitoring System shortly, which includes tyre (internal air) temperatures.
    Now I appreciate its the actual tyre tread temperature which is more important, but as a guide I wanted to find out what the internal air temperatures should be for optimum grip and performance when taking the car on the track?
    I need to set the upper warning alerts on this new system and didnt know where to start.
    I read an article from Toyo 888 who suggested the optimum tread temperatures were between 85C and 95C, and ideally a maximum difference across the tread pattern of 9C.
    But that didnt tell me what I should guess for the internal air temperature (which is what my gauge measures)
    I then wrote to Goodyear UK and got this reply...
    Steve
    Thankyou for your email.
    I am making an assumption that your system measures the air temperature inside the tyre, which is linked directly to tyre pressure. This shouldn't be confused with surface tyre operating temperatures which are normally measured with a pyrometer. In all of our track work, it is the surface temperature that we measure, not the air temperature, and then adjust tyre pressures to ensure we have the desired footprint on the road to even out the temperatures across the tread face of the tyre.
    Therefore, the focus should be on maintaining tyre pressures. Our recommendation for track days is that the pressures when hot should be no more than 5% more than the standard pressure for the car (or equivalent to the 'high speed' tyre pressure recommendation for your car, if this is listed in the handbook). Often, this means you may have to lower your cold tyre temperatures to keep the hot pressure in this range, but this depends on track temperature, the circuit and the duration of your stint.
    I'm sorry that there is no simple answer, but experimenting with cold tyre pressures to get the right hot pressure reading will ensure you get the optimum performance.
    Regards
    Goodyear UK
    Can't argue with that but what do I know ........ do you need any pit crew for the track day ....
    spoons
    Guest
    Quote Originally Posted by Tadpole View Post
    In my little fantasy, I've always dreamed of a Vectra BTCC works car and Vectra-C.com independant team....
    How well do you think we would do -
    Quote Originally Posted by spoons View Post
    Who knows till we try ........
    spoons
    Guest
    lol... can you imagine the fights.....
    I'm driving next !!!...
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    I think that would depend on how quickly the car could be snowfoamed, clayed and detailed during the pit stops
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Somebody I've seen a couple of times who drives a Murcielago professionally for a living on a track just uses standard pressures as per Lamborghini. He gets through 4 tyres in a day anyway!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you looked into nitrogen instead of air. It's less affected by heat so pressures are more stable from cold to hot. Most good tyre places offer this service now.
    Air is 70% nitrogen anyway... If you want to reduce the thermal expansion but, use pure oxygen...
    spoons
    Guest
    I'm looking into this at the moment....
    I suppose I can use Nitrogen most of the time and if I have to lower my tyre pressures at the track... just top it back up with air until I can get them recharged with Nitrogen again.
    Just got the Tyre Pressure Monitoring System installed this afternoon, just waiting for the tyre/wheel transmitters to go in now.
  1. tyre pressures
    By waynevvti in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2012, 21:22
  2. tyre pressures
    By DAVIDD88 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 11:59
  3. 215/50/17 Tyre pressures
    By ian1401 in forum Handling & Braking
    Last Post: 31st July 2011, 19:09
  4. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  5. Tyre pressures for 225/40 r18
    By Agoogy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2007, 11:58
