Thread: key fault wierd
    Regular Member sri_joe's Avatar
    Accrington
    Default key fault wierd
    ok my key buttons stopped working this afternoon so replaced the battery and still nothing, got the spare and all was well and then after work the spare did exactly the same and the other began working again. so all in all one working key at a time but never together. just wondering if anyone else as had this? iam just worried in case i end up leaving work and end up stranded in the car park
    cheers in advance
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    had that last night but woz ok once i started the car
    11 Post(s)
    Quote Originally Posted by sri_joe View Post
    A flat keyfob battery won't prevent the car from starting. All it will do is prevent the doors from remotely unlocking.
    You can still unlock the doors with the key in the drivers door lock but the alarm will sound - which can be muted by putting the key in the ignition.
    I take it you've tried the resync procedure as mentioned in the handbook?
    Accrington
    wasn't aware of the resync procedure because i haven't got a handbook, but will look into i cheers
    Regular Member fingers66's Avatar
    Carpe Diem
    To reprogramme, put the key in the ignition, turn until you get the dash lights, then press the fob buttons. If successful, the central locking will activate
    11 Post(s)
    There are one of two methods.
    It says the following in my 2007 handbook.
    "After a battery change, unlock door with key in lock, see page 69. Inserting the key into the lock synchronises the radio remote control."
    The other method is to put the key in the ignition, turn till you get the dash lights, then press either of the fob buttons within 30 seconds. The C/L will activate if its worked.
  1. Wierd fault code U2106
    By MX333 in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2011, 20:40
  2. Wierd wiper fault
    By Bobbyp in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2010, 18:26
  3. What a wierd Dream
    By Brocks in forum The 'Off Topic' room
    Last Post: 3rd July 2008, 10:27
  4. Its a wierd one but need help!
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 21:29
