Results 1 to 10 of 11
Thread: Chirping noise when turning left
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default Chirping noise when turning left
    lately im getting an odd noise when applying lots of left lock on the steering. Doesnt happen with right lock though which is odd.
    The noise is on/off and doesnt seem to get more or less frequent with speed. However it is very quiet and is barely inaudible with the windows shut
    with the windows open however, it almsot sounds like squeaky brakes but im not on the brakes, and it can happen at any speed while applying left steering lock so its definately not tyres breaking grip or brakes.
    any suggestions ? i know its a bit of an odd one.
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I've heard some power steering units squeal or chirp on full lock...but this is usually in both directions, and considered to be normal...
    Some cars...especially late 90's fords used to judder the steering wheel on full lock.
    As it doesn't seem to be affected by road speed, we can discount anything rubbing in the wheel housings.
    If it is affected by engine speed then you would assume some form of drive / cam belt rubbing / slipping.
    Personally, I would err towards the power steering.
    does it even with small ammounts of lock
    its still under warranty so im going to book it into the dealers. Just would like an idea as to what it might be as to whether it will be covered under warranty or not.
    Regular Member madman's Avatar
    nottm
    tried feeding the budgie?
    i did wonder if id chained him down too hard
    ive had so many problems with my VXR lately, im not sure if im just being paranoid, but i think i can feel some unwanted vibration comming from the front left wheel. Plus after taking the wheel off for a good clean, the nuts have come loose twice now.
    Each time ive put it down to me not tightenning them enough, but twice ? i'm sure somethings amiss. Trouble is, when i had the wheel off for cleaning i deliberately had a look and everything looked and felt fine.
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    cv joints ok?
    spoons
    Guest
    Quote Originally Posted by MrLOL View Post
    Thats worrying..
    Dont know what the answer is to that????
    WGAF#5
    is it not the power steering purge pump ? hence why it only does it in one direction
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Possible steering rack...check power steering fluid level...the seals may have gone...mine did...new rack under warranty at 24K miles.
    Regular Member sharpo's Avatar
    Jun 2009
    York
    Mine made a similar noise to what you describe, for me it was the strut top mount that needed lubeing.
    orrible noise too.
    With the car wheels off the ground A bit of lube was squirted in the general direction up into the strut top area, that sorted it, oh and the spring seat at the bottom was lubed too.
    Hope this helps.
  1. vibrating noise when turning left/right
    By valhalla in forum Suspension, Wheels & Brakes
    Last Post: 3rd July 2021, 14:20
  2. metallic scraping noise when turning left
    By brasch in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2013, 01:07
  3. Noise from F/O/S wheel when turning left
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 23:24
  4. Help with Chirping Noise
    By rossc1976 in forum Engine & Drivetrain
    Last Post: 13th October 2012, 16:36
  5. chirping noise
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2011, 20:38
