Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: URGENT Help needed car isnt running very well
    Regular Member vanquis1979's Avatar
    gainsborough
    Default URGENT Help needed car isnt running very well
    Hi got a problem with my cdti 150 sri car had a misfire this morning betwenn 1800 & 2200 in all gears and within 2 miles its lost power wont rev above 2500 spanner lights was coming on then off, then on all the time... now the spanner light has gone off and the orange engine light is on, theres no smoke just sounds very rough and no power? its sounds like its running on 3 cylinders (like a petrol) and the trip computer was reading 44 mpg and now only reads 28 i have checked to see if the 3rd injector has been changed and it hasnt before christmas it had new inlet manifold and full major service done and in feb was serviced again milage is 93000, can anybody help please i go on holiday monday
    Sunny Dartmoor
    Must be that exhaust you bought,i'll take it off your hands m8,probably only meant for a petrol anyways
    Only kidding m8 Have you checked your EGR???
    gainsborough
    can the egr make the car run like that?
    Sunny Dartmoor
    I thought it could,sure its been talked about quite alot on here somewhere
    gainsborough
    having the car diagnosed in the morning just hope its a cheap fix
    Sunny Dartmoor
    Good luck m8.........
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Sounds like the 3rd injector, if like you say its not been changed.
    gainsborough
    would it make the car run like its on on 3 cylinders? dan and lacking power
    Mar 2007
    Bristol
    mine had similar symptoms - the RAC towed it away yesterday saying it was a suspected blockagein the exhaust system - i've already had the injector wiring and egr valve done so it's not them......
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by vanquis1979 View Post
    Yeah for sure, as it won't be powering the injector the same and will make the same difference as removing a plug lead off a petrol.
    Its only about £14 for the field kit and takes about 1hr to do properly.
    Remove the 3rd injector plug, spray some contact cleaner in the plug and then connect/disconnect a few times and see if that helps - if it does then its that.
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT HELP: Zafira 2003 1.8XE poor running issue, not idling
    By merikiito in forum Engine & Drivetrain
    Last Post: 17th May 2012, 17:34
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed!!!!!!!!!!
    By johnnyg in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2008, 14:29
  5. urgent help needed
    By LISAJANE0410 in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2008, 15:21
