Results 1 to 3 of 3
Thread: Rear end noise
    bolton
    Default Rear end noise
    hello every1, got a problem the rear end of my vctra when going over a pot hole or broken roads rattles and knocks, if i drive over a pothole it will knock a second later but really loud.
    i have changed the rear shocks and anti roll bar bushes with no luck,
    was wondering if you guys could help. pleeeeeeeeeeeease!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Yas it sounds like your rose bushes need replacing,you will need the tool to remove and refit new bushes,they are a bit of pig to fit.they are about £20 for the set on e.bay.sometimes they are that tight that you have to remove the complete arm to remove the bushes.stand behind car do the rear wheels lean in at the top if so it's your bushes
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    Quote Originally Posted by yas 2.2dti sri View Post
    Although you have changed you rear shocks and AR Bushes, it sounds like it is the very common problem of a broken spring. If the springs all check out fine I'd then be looking at the rear upper control arms, again another very common problem.
    Bri.
  1. Noise from rear
    By stanlee in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2012, 13:07
  2. Noise from Rear
    By DesignforLife in forum Bodywork & Interior
    Last Post: 21st December 2009, 19:35
  3. rear noise
    By themurf in forum Introduce yourself.
    Last Post: 19th May 2009, 15:45
  4. Rear Noise
    By johnK in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:31
  5. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
vectra rear end noise
