Results 1 to 2 of 2
Thread: Lazy starting
    Malton
    Default Lazy starting
    Now I've finally got the 1.9 cdti back (with new ecu) it's a bit lazy at starting - but I'm grateful it starts at all!
    It seems to start better 2nd attempt (if it doesn't go first time), and better when hot/warm.
    Point to the heater plugs?
    G
    Regular Member ptrehearn152's Avatar
    norfolk
    it could well be, but it could also be leak off pipes starting to split around the ends, what happens is if there is a slight air leak at the leak off pipes and the car is left standing over night for example it allows the fuel to drain back towards the tank and cause a bit of an air lock thus taking longer to start, but equally if you have just one duff glow plug this will make starting more difficult, if you take it to an auto electrician they can test them in situ, takes about 5 mins and you'll know for sure. hope this helps.
  1. Lazy, incompetent, or both?
    By Grumpy1954 in forum The 'Off Topic' room
    Last Post: 13th February 2011, 23:50
  2. Lazy Central Locking
    By carmadone in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2009, 14:07
  3. MY AFL's Got A Lazy Eye
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 20:29
  4. lazy day off
    By ditchp in forum General Chat
    Last Post: 15th January 2008, 11:00
  5. my fat boy lazy 2.2 sri auto
    By HOLDEN in forum Quick Photo Album
    Last Post: 21st June 2005, 22:15
