Results 1 to 10 of 14
Thread: Broken front coil spring
    Apr 2009
    Derby
    Unhappy Broken front coil spring
    Well after reading the many threads of here regarding the front coil springs snapping on people, I never thought it would happen to me.
    I was driving to Tesco about an hour ago and noticed a bumping/knocking noise coming from the front of the car. When I got home I jacked the car up and noticed the front drivers side spring had snapped in half. I've booked it into my local dealers for them to fix under warranty. One thing i'll make sure they do is use the correct springs as mines a sri.
    To be honest the only reason I never thought it could happen to my car is a 56 plate and only done 31,000 miles.
    Cambridgeshire
    It's because they are made out of chocolate mate you want to get some Eibachs under there instead
    Apr 2009
    Derby
    Quote Originally Posted by parsco View Post
    I'd love to but I may aswel get the spring replaced for free this time. If it happens again out of warranty then i'll fit some decent springs myself.
    Does anyone know if vauxhall will replace the springs as a pair or just replace the broken one?
    Cambridgeshire
    I am pretty sure that they should be doing them in pairs, it's like brake pads or discs, you don't do one side and not the other. Hopefully Vauxhall should know this mate, then again we all know what they can be like
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    they should do the pair m8, make sure you tell them you want both doing
    expat in mountain region of romania
    just happened to me today was reversing off drive tyre was flat so moved car back in jacked up to change wheel guess what spring snapped gone through tyre also, im p@@@ed off now
    Aug 2009
    Suffolk
    Wow, i can see this is a common problem. What a load of tosh.
    cardiff
    Vauxall replaced both my back springs, as one had snapped,I did not even know ,put it in cause car felt strange on front end a bit vague , yes they replace pairs and the warranty is for 4 years , this happened to me about six weeks ago.
    Full Member Big Sig's Avatar
    Quote Originally Posted by JDMDC2R View Post
    Its a common problem on a lot of manufactures cars
    Aug 2009
    Suffolk
    Not on my 13 year old Hondas
  1. God dam it, Another coil spring broken!
    By Mads in forum Suspension, Wheels & Brakes
    Last Post: 24th December 2012, 09:09
  2. Broken coil spring
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2011, 07:24
  3. Broken rear coil spring on 04 Signum
    By INCONTROL in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 17:34
  4. Broken Coil Spring??
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 5th November 2009, 23:20
