Results 1 to 10 of 27
Thread: 120 8v EGR Valve blanking....
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default 120 8v EGR Valve blanking....
    Recently cleaned out the EGR on my 120cdti with 73000 put it all back together and it didnt really do alot performance wise. I was thinking to myself about blanking it off but heard about fault codes.
    I then read the thread talking about the 'Fiat' plate which almost blanks it off.
    This got me thinking.....now correct me if im making a tit out myself but could you 'crimp' the bottom pipe coming up from the exhaust to make the hole smaller but leaving a big enough gap so the sensors take a reading.
    Would this work or am i in wonderland?
    EVERYWHERE
    Quote Originally Posted by smiley-sri View Post
    It would,but it's a bit of a botched way of achieving what you want.You'd be better off getting the 'Fiat' gaskets.
    I've tried blanking the EGR off on my V6 with varying degrees of success,but I'm getting code p0105 (MAP sensor circuit malfunction).Which means that the sensor was probably not reading sufficient vacuum in the inlet manifold when decelerating.The MAP sensor has some control over the injection timing and fuelling under part throttle conditions which apparently can affect fuel consumption.Since I took the blanking plate off,fuel consumption now seems to be much better ???
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    What about partially blocking the take off on the zorst manifold. I presume its the same as the petrol models where one port has a deep channel in the side?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by diesel dog View Post
    Didn't you state that your fuel consumption was much better with the plate on?
    Also, where did you put the plate on? The EGR side of the pipe or on the manifold? Not sure I want to do it anymore...I'd get rid of the P0400 rubbish but get P0105
    EVERYWHERE
    I think that's what he means.The problem is that if you crimp it and it throws up a code,you're then in a spot of bother!
    You can do the same thing on the V6 (block not crimp),but it doesn't really matter where you partially block the EGR pipe because anywhere along its length (up-stream or down-stream of the EGR valve) will slow down the flow of exhaust gas.
    Vehicle : SRi
    Mileage : 137000
    No not the pipe. In the cast flange that butts up against the head. On the petrol's the passenger side port has a cut out, so looking at the head it has the 4 zorst ports and then one little port for the zorst gases to feed the EGR. The Manifold bridges the exit port an intake port to the EGR. On the 2.2 its easy, you just fill it with weld but the egr is monitored differently so fully blanking it is simple with no side affects.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    P0105 (MAP sensor circuit malfunction).Which means that the sensor was probably not reading sufficient vacuum in the inlet manifold when decelerating
    This is the only sensor that is directly collecting data on vacuum etc. in the inlet manifold. Is it the MAP sensor?
    Before a good rub and brake cleaner it was all sooted up. I wasn't easy to clean it this well..
    EVERYWHERE
    Quote Originally Posted by Celes View Post
    Me too,hence the ??? But now it's even better.
    The manifold,where the gasket with the tab on it is,just after the corrogated part of the pipe.Unfortunately the problem with 'mods' is that under certain circumstances they are likely to throw wobblies.
    The MAP sensor is also GMs way of checking the function of the EGR valve,this usually happens when the vehicle is decelerating.So if you're going reasonably quickly,then take your foot off the gas,and the sensor reads too low a vacuum because the EGR valve is not opening correctly (or is blocked some other way) ........spanner light !
    EVERYWHERE
    It doesn't look like a pressure sensor to me.More like a temp sensor ?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    By inserting the blanking plate you don't really prevent the EGR from getting clogged up. All you do is reduce the amount of **** going back into the cylinders. Am I right?
    After a while you would still get the P0400 code, as the EGR would get cacked up...AGAIN
    I'm curious on what it is. EGT sensor?!
    But where is this damned MAP sensor?!??
  1. Blanking EGR valve
    By mtqn in forum Engine & Drivetrain
    Last Post: 17th July 2012, 14:11
  2. blanking egr valve
    By Garfo in forum Engine & Drivetrain
    Last Post: 12th May 2011, 14:43
  3. Blanking Egr Valve
    By Simo87 in forum Diesel Engine related
    Last Post: 31st May 2010, 17:22
  4. Blanking EGR Valve
    By Nav-Man in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 19:31
  5. Blanking off EGR Valve
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2010, 19:12
