Results 1 to 10 of 20
Thread: 35mm Apex Springs
    Regular Member Cossy's Avatar
    East Yorkshire
    Default 35mm Apex Springs
    I have just fitted some 35mm Apex springs to my 2.2 Sri and they look great...although its only lowered it a little, ride is lovely.
    Its already on bilstein B4's to thats helped no end. The only problem is, theres a knocking from the rear springs.
    if i hit a bump at speed and sometimes on normal bumpy road there is a strange knocking sound from the rear springs, a loud knock about half a second after the bump.
    Ive checked the springs and everything looks fine, followed the instructions when fitting, "apex" written on the springs so be placed so it can be read normally. This ment the righter coils went to the top.
    I know other people have fitted them but can anyone tell me if they are upside down, i did follow the instructions to the letter but i can only see this been a possible problem.
    Any advice would be helpful.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    sorry i don't know anything of your problem......wheres the pics then lol
    East Yorkshire
    I haven't had chance to take any yet, was late when i finished it last night and its done nothing but throw it down with rain since i did it.
    Really just wanting to know which way others have fitted apex springs, tight coils to the bottom or top.
    East Yorkshire
    Anyone got any pics of their apex 35mm springs fitted on he rear? Help!
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    mine will be going in on fri to get the -35 apex springs on, a bit of a wait tho..free bump for you.....some one else will help i'm sure
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    just looked in my instructions for them m8 it says "install springs so that their markings can be read in the normal way. this indicates corrct positioning"so sounds like you have them the right way round
    East Yorkshire
    Thanks for the bump!
    Thats exactly what i thought, but im sure i saw a thread a month ago when i bought mine that someone fitted them with the righter coils to the bottom, which according to the instructions would mean they installed them upside-down but they didn't have any problems with them.
    Im now just wondering if they are positioned correctly on the rubber mounts as if i swivvel them around they are close to the body or the lower arm as they aren't perfectly round. Just wondered where others had positioned them?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Its probably where they are bedding in and the travel is larger than normal making the spring not seat properly hence making the knocking noise when the spring goes back into the correct position. Im not saying this is what your problem is but let them bed in then check if its still doing it. put some weight in the back to help bed them in a bit quicker, should do 500 miles to be absolutely sure they are done.
    Regular Member david.aka.judas's Avatar
    Suffolk
    have thought of emailing apex - they may have a solution.
    East Yorkshire
    Well, just filled my boot full of rubbish, old set of wheels etc, its low as heIL! hoepfully that mite make it settle in a touch more.
    Ill give apex an email and see what they say.
    If anyone has any pics of their fitted or had the same problems, please let me know what uve done!
  1. vectra c turbo just fitted apex 35mm springs
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2012, 19:43
  2. rear apex lowewring springs 35mm
    Last Post: 3rd May 2012, 13:21
  3. 35mm drop on Apex Springs
    By bobmcn in forum Handling & Braking
    Last Post: 29th April 2012, 21:19
  4. FK 35mm springs before and after
    By vekky c in forum Styling
    Last Post: 22nd February 2012, 08:42
