Thread: 1 key not working
    Malton
    Default 1 key not working
    Now that I've finally got my Vectra back one of the keys isn't working, it's the one that I kept while the car was being repaired.
    It won't open the doors and when I put it in the ignition i get a picture of a car and padlock on the dash.
    I've looked in the hand book and it mentions re-sync by putting it in the ignition. This hasn't worked. I've also tried it in the ignition (turned to position 2) and pressed lock-unlock (I read that on the net somewhere).
    Any ideas? Is it a dealer job?
    Cheers,
    G
    Plymouth
    what work did u have done on the car??
    sounds like they reset the comp and reset the keys
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    must have reset the CIM you'll need to take other key to vx and get paired... same happened to me . 2 min job
    Malton
    New ECU
    Nov 2007
    yep defo need 2nd key prog into CIM... should be free included in with the work you got done...
    I feel the place you had the work done (if they did re-set the CIM) should have asked if you have another key as it will also require re-programming hth ...........
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    As already been mentioned, 2min job for the stealers and they should have asked if you had other keys as they would need programed. Again as already stated above this should be free for you as they should have done it or asked you to bring your extra keys along at the time.
    Bri.
    Malton
    Thanks guys, I'll get it sorted.
    G
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
