Thread: changing the fuel filter on a DTI
    Regular Member eaglepva's Avatar
    Up North
    Default changing the fuel filter on a DTI
    Hi, can any body give me any advice on changing the fuel filter on a DTI
    cheers
    Ash
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Its pretty simple mate... although the dti's arn't self bleeding... the fuel filter is at the top right of the engine and in a casing. cap of casing is held in by a long screw (torx) undo screw remove old filter, put in new filter and top up case with DERV. replace cap and expell all air by pouring more DERV down the screw hole in the cap until its full to the brim replace screw and crank over... Make sure you dont spill any and if you do wipe it all up. HTH
    Up North
    Hi mate thanks for the reply sill question but what is DERV? is it diesel?
    Nov 2007
    yep (diesel engine road vehicle)
  1. HELP!! after changing fuel filter
    By williamM in forum Engine & Drivetrain
    Last Post: 30th December 2010, 17:49
  2. Changing Fuel Filter
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 10:21
  3. Changing Fuel Filter
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 11:41
  4. Changing Fuel Filter
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 8th February 2009, 17:36
  5. changing the fuel filter?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 21st December 2008, 17:10
