Results 1 to 10 of 13
Thread: Vectra B not C :)
    Cwmbran/Newport
    Default Vectra B not C :)
    Hi All,
    My old b has been parked up since i got the c, and yesterday cleaned it and started her up. All ok to start with but then sounded like it needed oil, so topped it up but still the same noise.
    Checked the oil once again, but still the same noise. Anyone have any ideas on this?
    Could it be the oil pump or something? or oil pressure switch. Its an sri 140, i'm sure other on here must have experience on the b
    Also someone said it could be to do with the nreather pipe, could this cause an issue if it were clogged?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Could be a sticky valve with sitting mate
    Cwmbran/Newport
    Thanks John, if its a sticky valve how to i unstick it? Checked the head and there appears to be oil in there so not bone dry, also when adding fresh oil, noise remained and didn't stop.
    May 2008
    Derbyshire (south)
    These ecotecs don't like sitting around, leave it to get hot, then it will quieten, it will go (or it did on mine) eventually, next time you start it.
    Its the stem guides you can hear.
    Cwmbran/Newport
    Cheers guys, thing is i don't want it to seize if there's not enough oil in there, what would you class as being enough oil, also what are stem guides?
    11 Post(s)
    Quote Originally Posted by Matt Cutler View Post
    what would you class as being enough oil?
    Above the min line on the dipstick, but not over the max line.
    Birmingham
    Try putting some STP engine wear protection in?
    Any piccies mate:
    Bye bye Vec B
    - Hello Siggy!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    thats just the lifters that have drained of oil bud especially if its been sitting around for ages
    Cwmbran/Newport
    Thanks for the info guys, if i let the engine run will this *unstick evrrything, lifters etc? Slightly worried by the noise it makes and also the oil light seems to be flickering, then goes off. My worry was that oil wasnt reachibg the head but after cleaning the cap then replacing it and checking it, it had fresh oil on. Will stp also help?*
    Cwmbran/Newport
    Hey All,
    Is there a clear way of checking oil in reaching the head other than checking the cap?
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
