Results 1 to 10 of 15
Thread: wet floor on passenger side
    Jul 2009
    portsmouth
    Default wet floor on passenger side
    picked up the 54 plate estate, drove it about 450 miles over the weekend, got home and the passenger side carpets are wet, heater still blows hot and cold, i thought it might be the matrix, or am i looking for something else? the only other issue i had was the rear washer spray didn't work, but the front does, any help would be apprecieated
    May 2008
    Derbyshire (south)
    Have a look Here,, for the water issue, as for the heater matrix or blowing hot/cold, could be down to the same issue, & possibly a new pollen filter.
    washer bottle, could just need topping up, if its low the rear one will stop first. It may also just mean the pipe at the pump end has come off it.
    Jul 2009
    portsmouth
    didnt make that to clear did i, i was under the impression if the matrix had gone, i would not get hot and cold air blowing, but i have, sorry, if i am wrong please tell me though
    May 2008
    Derbyshire (south)
    Once you have un blocked the bulkhead plug the water will stop flowing onto it & into your footwell. new pollen filter as it sounds like it gonna be pretty well gunged up.
    Lets see if the heater plays ball then??
    Jul 2009
    portsmouth
    many thanx that hole was blocked and sitting in water!!! unblocked now though, so gotta dry it out, many thanx mate
    Quote Originally Posted by vinceverrier View Post
    Don't forget the other side just in case .................
    Jul 2009
    portsmouth
    i didn't done them both, many thamnx
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I check the pollen filter and the drain underneath regularly ever since the same thing happened to me.
    Regular Member grumpano's Avatar
    North West
    Me too,Check mine every month. Its always got leaves in it!
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    checked mine today, and guess what, ?...yep full of leaves.
    tried to find the one on the other side, but didnt fancy removing all the plastic, so just guessed where it is and used a wooden skewer to give it a prod!
  1. passenger side floor soaked
    By MORGIE8153 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2010, 15:00
  2. wet passenger floor in 52 reg pre facelift..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2009, 12:15
vectra c water on passenger side floor
water on passenger side vectta cdti
