Results 1 to 10 of 11
Thread: difference between HID's and xenons?
    Regular Member Adz86's Avatar
    Aug 2009
    West Yorkshire
    Default difference between HID's and xenons?
    as title, whats the difference, are xenons just a bulb and HID's an actual kit? just that the car im getting says it has xenons, not really a selling point if its just a bulb is it?
    Edinburgh
    just different names for the same thing I think. you'll find them interchanged. Although watch out for people claiming to be selling "xenon bulbs" and are selling Halogens
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by knoxvillain View Post
    Yeah, thats pretty much spot on.
    You'll find Xenons refer to the factory fitted kit, while HiDs refer to the aftermarket ones, ultimately are the same thing, but "some" people think that a car with projector style lights are Xenons !!!!
    Regular Member Pete B's Avatar
    Malvern
    "Xenon" bulbs is actually correct, the real difference between HID's and ordinary bulbs is the fact that HID's (High Intensity Discharge) are discharge lamps (like a camera flash but on all the time) and have no filament wheras ordinary bulbs are a heated filament. Some filament bulbs are filled with Halogen (hence the name) wheras Xenon filament bulbs are just that, bulbs filled with xenon and they can be run slightly hotter (whiter light, e.g. Philips 'X-treme', Osram 'Nightbreaker' etc) than halogen filled bulbs. Still nothing like HID's though. The name confusion arises because the discharge gas in HID's IIRC is xenon.
    OEM fitted HID's are usually referred to as 'Xenon' lamps as Dan says above.
    One just has to be aware that in purchasing extra bright 'xenon' filled bulbs that they are still getting only a filament bulb, not HID's.
    If Adz86's proposed car is advertised as having 'xenon's' (is it a 3.2 GSi as per profile?) by a reputable seller, then it almost certainly already has OEM HID lamps fitted.
    Aug 2009
    West Yorkshire
    hey thanks for replies, very helpful, does say xenons on the advert so im hoping they are the said manufacturer fitted
    Glasgow
    Yeah your GSi will have factory fitted zenons with heated high pressure washers
    Regular Member ispitanfart's Avatar
    Jul 2009
    Suffolk
    about thirty quid each....
    Aug 2009
    West Yorkshire
    does it have to have washers? it has got them but i think i read on here somewhere someone saying they might fail m.o.t if it doesnt, what do they do other than clean the headlight
    also whats the life of a xenon and how much to change if one goes?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Adz86 View Post
    Retrofit HiDs don't "need" washers to pass an M.O.T. People will argue quoting this and that, but the fact of the matter is, at present you don't need washers on your car when retro fitting HiD kits (the washers do just that, clean the headlight to keep the beam pattern intact).
    The life of the bulbs is about 3000 hours, which is about 10 times longer than you're average halogen bulb.
    Full Member gibbon7000's Avatar
    lincs
    IIRC Factory fit Xensons require washer jets by law.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
  1. Xenons
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 21:06
  2. xenons for a sxi
    By vectranath in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2009, 21:23
  3. Xenons
    By ukmayhem in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2009, 21:46
  4. GSI's and Xenons
    By tommo2000 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2006, 23:34
  5. Xenons
    By woodster in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2006, 13:50
