Results 1 to 10 of 25
Thread: L.E.D sidelights
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Thumbs down L.E.D sidelights
    Hi all,
    just thought i'd mention that i bought a set of white led sidelights off ebay last week and tried them today but the computer system doesn't like them. It prompted me to check the right parking light, which i clicked ok to, then the same for the left, but the small display in the rev counter displayed the bulb symbol. Got out and checked em and they were working fine. Guess they work on a different voltage or draw less current or something. I dunno. Had to take em out again though. Don't know if anyone alse has tried em but i thought i'd let you all know.
    Hertfordshire
    Yes m8, it has been discussed somewhere on here before but some time ago, LED's are a bit of a no no on the Vec C, they do not draw enough current and so give the bulb checker a heart attack.
    May 2006
    somerset
    Ah, thought that might be the case! And i thought you'd probably all tried them before anyway! Oh well!
    Jan 2006
    Skynet HQ EMEC#5
    You could still use them in the front interior light, they are ok in there.
    Regular Member hsmeets's Avatar
    May 2006
    right next door to my neighbour
    Led's normally draw less current than a regular bulb.
    Let's say the bulb is 15 Watts (check this) at 12 Volts then it draws 15 / 12 = 1.25 Amperes. The LED's you bought probably draw not much more than 0.3 Ampere, but you should confirm this by measuring the current with a multimeter. The low current triggers the computer into believing the bulb has died. You need additional current to keep the computer happy.
    The checkcontrol can be fooled easily if you place a resitor in paralel with each sidelight.
    To draw an extra 1 ampere at 12 volts you need a resistor of 12 / 1 = 12 ohm, it also must be capable of dissipating: 12 volts times 1 ampere = 12 watts
    These resistor will cost around 1 or 2 pounds each and can be bought at any regular electronics shop.
    Summary: lookup the watt's of the original bulb, measure the current thru the new LED lights (or ask the seller or look at the spec sheet):
    12 volts divided by ( (Watts of bulb divided by 12 volts ) minus (current thru LED) ) = resistor Ohms (should be somewere around the 8 to 15 ohms)
    Get a resistor capable of dissipating at least the same watts as the original bulb and you'll be save not burning the resisitor.
    You now mimic the powerconsumption of the original bulb and the computer should be happy.
    This also applies to the rearlights if anyone would care to upgrade them to LED lights (if such mod would be roadlegal anyway)
    Huib
    Quote Originally Posted by storey_3000
    Hi all,
    Oct 2006
    Lancashire
    the leds that crazy leds sells from vvoc.com supposedly dont trigger the warning system - just thought id mention it!
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Quote Originally Posted by stehanson
    Any idea what ones apparently dont trigger the warning light?.
    I had a look at CrazyLED's website, but it appears to be down just now.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Those little four LED clusters look great in the front, espechially in blue! Mr Nick Nick didn't think so though but white ones would be fine. I'll be taking a look at Crazy LEDs myself.
    Oct 2006
    Lancashire
    yeah, its a new site that he has and isnt working properly yet, if your a member of vvoc to, just pm him (unless his box is full) - everyone raves on there about his white sidelight leds and they are not meant to throw up probs with the bulb check sensors - Ill belive it when I see it though!!
    Falkirk, Scotland
    I spoke to him on the VVOC forums.
    He said that the LED's he does work 100% with the Vectra B's bulb warning system, but he has not tested them on a Vectra C.
    I'm guessing they wont work, but I might order a pair anyway, just out of curiosity.
  1. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  2. sidelights
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2011, 17:02
  3. led sidelights
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2011, 16:22
  4. those who have led sidelights..
    By john-d in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2010, 14:52
  5. what sidelights???
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 02:38
