Thread: What is 'this' ?
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default What is 'this' ?
    On the connection above the fuel pressure regulator,part of the fuel loop pipes on the 2.2 Direct.Not sure if it should be part of the connection and its came loose or its just 'there'.Its the white 'disc/clip' part
    Nottinghamshire
    I think they are markers to help ensure the correct pipes are connected to the inlets/outlets or to mark which are inlets/outlets. There are several of these on the various fuel pipe connectors on my car.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    there a production clamp used on the blue locking clip only use once when new at the factory when fitted saves time fitting so it is left to its own devices on the fuel pipe there all over the fuel pipe system weather it be petrol or derv .....no use for them only in the factory
    Apr 2006
    Inverclyde
    On another note. How do you remove the pipes? The 'blue clip' system seems quite tricky
