Results 1 to 10 of 11
Thread: 2.2 Direct Fuel Pump relay
    Tyneside
    Default 2.2 Direct Fuel Pump relay
    My uncle had his car on Tech 2 and it was diagnosed as the fuel pump relay. Any chance you know where it is. The car runs fine and then decided to stop with EM light coming on.
    Not sure if it is the relay as it works fine and then stops where normally if a relay is bust it wont work full stop. TIA
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    PM replied mate. I'm still having trouble finding it, Google searches bring up in many cases its on/by the pump (under black rubber disk under back seats) The Directs as you know run 2 pumps, the one in the tank which is electrical and the cam operated one on the rail. Is it defo not a HP pump issue?
    You know Plasma might be a good un to ask.
    Tyneside
    Had a look under the seat and there was nothing there bar some wires and pipes. The car will run fine and then thEM light will come on and the engine will die with no prior warning, he hasn't had limp mode yet just cuts out then has to wait a few minutes for it to re-start.
    Tyneside
    The reader never came up with a code, it said the fault was:
    Fuel pump relay, low speed fan.
    If that makes anyone the wiser.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    fuel pump relay for the pick up pump in the tank is situated on the rear of the rec in the boot you need to unbolt the rec and have a look on the rear i think it is red from memory ........
    Tyneside
    Cheers Benny you're a star mate Oh what do you mean by ''rec'' though mate?
    Feb 2006
    dudley
    rear electrical center ....fuse box in the rear .....
    Tyneside
    Awesome mate, thanks again
    Tyneside
    Thanks for all the help guys, he's decided to go for the fuel pump as that seams like the more likely cause.
    Mar 2016
    livingston
    Vehicle : vectra c
    Trim : hatchback
    Engine : z19dth
    hi guys I have a veccy c 09 plate 1.9 cdti cuts out all over the place ,thought I had a crank sensor issue but symtoms same as yours since I have ruled out crank sensor by changing it do you think I could have the same fault as I am so close to giving the ***** a make over with a baseball bat .
  1. does 2.2 direct fuel pump
    By coolj in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 14:47
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. 2.2 Direct Fuel reg and pump
    By m623d in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2012, 14:06
  4. 2.2i direct fuel pump
    By gordy07 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 19:39
  5. 2.2 Direct Fuel Pump
    By Paul_NI in forum Engine & Drivetrain
    Last Post: 8th August 2011, 12:22
vectra 2.2 direct fuel pump fuse
vectra c fuel pump relay location
vectra 2.2 diesel fuel pump relay
relays in boot on vauxhall vectra fuel pump
vectra fuel pump fuse
opel 2 2 direct fuel pump
vectra c 2.2 direct fuel pump
fule pump relay on 05 vectra
vectra c 2.2 fuel pump relay
vectra c 1.8 fuel pump relay
vauxhall signum 2004 2.2 fuse box relays
vauxall signum fuel pump
where is the fuel pump relay on a vauxhall vectra 2.2 Sri 2005
vectra fuel pump located
zafira dti fuel pump relay location
1998 opel vectra 2.2 fuel pump relay location
vectra c 2008 fuel pump relay location
vectra c where the fuel pump relay
fuel pump relay on vauxhall vectra
Where is the vectra 2.2 sri fuel relay switch
diesel fuse box rely location on signum
fuel pump opel vectra 2.2 diesal
vectra diesel fuel pump relay
2.2direct sri relays
