Thread: OIL TYPE, fuel pump and 2 plastic straps
    Regular Member m1ke823146's Avatar
    Aug 2009
    derby
    Default OIL TYPE, fuel pump and 2 plastic straps
    Hi every please forgive me but im new to this forum and to vectra ownership, could anyone tell me what type/grade of engine oil i should be using, where the fuel pump is located and what the two plastic straps are for that are located on the underside of the tailgate? my car is an early vectra c 52plate 2.0dti ls 5door hatch, i was also led to beleive that vectra b's like semi synthetic oil and c's like fully synthetic which confused me as im sure i should be using fully synthetic but the vectra b's that had the same 2.0 dti engine as mine should be using sem synthetic? Many thanks in advance,
    mike
    Plastic straps ?
    Oil Type - Vaux semi will do if the car is not on eco service
    Fuel pump- Bolted to end of the engine (drivers side) the 1.9 cdti models also have a pump mounted in the fuel tank the 2.0 and 2.2 dti models dont.
    Welcome to Vectra-C.com mike
    Liverpool
    Plastic straps are for a fold up warning triangle.
    Aug 2009
    derby
    Quote Originally Posted by Rapala View Post
    Plastic straps ?
    Cheers Rapala, looking at the service book it is no longer on the 'eco flex service plan anymore! when you open the tailgate and look up there are two plasti clip/straps, looks a bit like you could unclip it and put a spare reg plate there, but ive put my umbrella there!
    Aug 2009
    derby
    Default re blueboys
    Quote Originally Posted by blueboys View Post
    cheers blueboys, any views on what sort of engine oil i should be using?
    11 Post(s)
    Quote Originally Posted by m1ke823146 View Post
    Listed on Vauxhall's website: 5w/30 fully synth for cars from 2002 onwards.
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    I am getting some oil for my car 5 litres for 10 quid from Vaux sure lad said sumit 40 ? but it is what they use for diesels anyway will let u know when I get it what it is but mines a 1.9 cdti don't know if they are diff
  1. Replies: 20
    Last Post: 12th February 2013, 09:21
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Replies: 19
    Last Post: 30th May 2012, 15:53
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
