Results 1 to 2 of 2
Thread: Potential Air Con issue????
    Regular Member swirl80's Avatar
    Jun 2009
    Default Potential Air Con issue????
    to follow on from a recent thread i started regarding an engine whine (dealer declared it was nothing but couldn't explain what it was or why it wasn't there the previous week.....), i've recently been getting another noise a more of a vibration/labouring/revs too high for the speed i'm travelling at which didn't happen consistently but more often than not it was when coasting to a junction, or pulling away slowly. Now, i have noticed that the noise becomes apparent when i switch the air con on or have it running. If i don't have the air con on i dont get the noise at all.
    Has anyone had this before? Is it the fact the air con unit is putting extra strain on the engine and its not revving enough to cope therefore giving a kind-of-a labouring noise
    As soon as i switch the air con off it doesn't happen.....
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Might well be the compressor on the way out. You switch the aircon on - the clutch engages and if say the compressor bearings have gone, then you get the strain on the engine as the compressor isn't spinning freely. You switch aircon off, the clutch disengages and the strain is taken off the engine. Sadly, the compressor is the expensive bit
    You might want to get it checked by an aircon specialist, or get under there and see how the compressor bearings feel to you - should be a nice, smoothly spinning pulley when engaged - no rattling.
  1. HIDS question, potential issue.
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 14:34
  2. Potential issue with Vectra V6 CDTI SRI 3.0l
    By gdallas in forum Vectra C / Signum Troubleshooting
    Last Post: 20th July 2011, 05:19
  3. Potential new car
    By plasma in forum South West - RO (vacant) / ARO - (dave234)
    Last Post: 17th June 2010, 22:01
  4. Potential Project Car
    By wotsthestory in forum General Chat
    Last Post: 5th January 2010, 10:16
  5. potential sri owner
    By stec in forum Introduce yourself.
    Last Post: 30th March 2009, 17:00
