Thread: Brake light warning....
    Regular Member swirl80's Avatar
    Jun 2009
    Default Brake light warning....
    i'm now getting a rear nearside brake light warning light but when i checked it its fine, is this a warning its on its way or a fault in the system??
    Mileage : 000
    I think you will find the bulb is about to give up. You will look another day and the side light will be taking over as the brakelight untill you replase the "duff" braklight bulb.
    Jun 2009
    ah, i see. No probs, i'll sort it tomorrow, was just curious as everything looked fine.
    cheers ed
    Quote Originally Posted by swirl80 View Post
    cheers ed
    As said, if the upper tail/brake light fails, then the lower tail light takes over the role of tail/brake light. At first glance you think all the bulbs are working, but look again and you might see that one brake light is at a lower level than on the other side.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
