8th August 2009, 17:27
#11
Originally Posted by
old cruiser
As Rushy says and if you are disconnecting the battery all together it's good practice to remove -ve 1st then +ve and for refitting it's +ve 1st then -ve.
Cheers Pete
The reason for this is if you slip with the spanner while undoing the +ve and the spanner is still on the batt terminal, you don't run the risk of shorting out the battery if the spanner hits any part of the bodywork because the -ve has already been disconnected.
Also be aware that if your alarm power sounder has a battery back up, first turn on then off the ignition and then disconnect the car battery within 15 seconds or the alarm will go off. Best to slacken the battery terminal first so you're not fighting time with a spanner.
14th March 2018, 14:54
#12
Big Dave
I know this an old thread - but just goes to show that the search facility does work That's exactly what I was after
