Results 1 to 10 of 11
Thread: When disconnecting the car battery.......
    North East
    Default When disconnecting the car battery.......
    to do a reset, which lead do I disconnect, the red one or the brown one, or doesn't it make any difference?
    Mileage : 000
    I always put the + live RED on first and the -negative on last.
    North East
    The battery is already in the car, i just want to do a reset, am I correct in thinking that just disconnecting one of the leads will do the trick, are you saying just disconnect the + red live one?
    Mileage : 000
    Yes disconect the RED Then leave it disconected for "well as long as you can" they recon about half an hour.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    always disconect a battery via the earth lead (brown) and always reconect it last ....
    North East
    and to do a full reset do you need to disconnect both the brown and the red lead or will just one suffice?
    Sorry for the numpty questions!!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The Neg (brown) is all you need to disconnect.
    Regular Member old cruiser's Avatar
    slough
    As Rushy says and if you are disconnecting the battery all together it's good practice to remove -ve 1st then +ve and for refitting it's +ve 1st then -ve.
    Cheers Pete
    Mileage : 000
    Quote Originally Posted by benny View Post
    Looks like I have been taking them off the wrong way round.
    North of Watford Gap
    Did a reset on my Signum recently when the instruments had all failed and I only removed the one lead. After the reset don't forget you will need to reset the electric windows to make the "one shot" function work again.
    PG
  1. For those disconnecting battery with ESP!!!
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 22:07
  2. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  3. Disconnecting battery...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 23:06
  4. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
  5. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
