Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: 3.0 cdti shuddering/juddering
    France
    Default 3.0 cdti shuddering/juddering
    I have previously posted about clouds of black smoke under hard acceleration and had lots of good replies. This is still unresolved and has actually gotten worse after towing a caravan for 500 miles. Now smokes under mild acceleration and even when revving at standstill. I noticed with the van on the back that it would hesitate occasionally at 2000 or 3000 revs when accelerating to overtake.
    I now notice that the car has pronounced shuddering/juddering in what I presume is top from around 1500 revs up. At first I thought it was the road surface but when I lift my foot from the throttle it is smooth. The shuddering instantly returns as I touch the throttle again even without increasing the speed. It does the same if I put it onto cruise.
    Car is 12/03 estate auto, 100K miles, serviced by Dealer as per book (last done at 92K, + cambelt, gear oil and brake fluid changed).
    Full Member Big Sig's Avatar
    could be a sticky injector or the valves in the hp fuel pump. Have a search as i'm sure mtc had his done.
    Fuel injection problem...?
    Mar 2007
    Beaconsfield, Bucks
    My car had this with the previous owner, it was a faulty injector, the juddering is the engine misfiring. The V6 is so smooth its less noticeable than in the 4 pots.
    France
    Thanks, all. Could a faulty injector also be responsable for the clouds of black smoke or the hesitation? I actually think the shuddering has been there a long time but only noticed it because I had some metal tools at the back which rattled as it shuddered.
    France
    Forgot to say I have never had the spanner light on. Would any fault codes be stored?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    1. Clean the EGR
    2. Try some injector cleaner IF the juddering is not severe
    3. Judder around 1500rpm - supposedly the suction valves on the fuel pump are faulty
    4. If you hear a knocking sound under hard acceleration from 1400rpm, 1 or 2 injectors are weak.
    Good luck.
    France
    Thanks, I'll listen out for that. The shuddering is not severe, its just that now I know it is there I am looking out for it all the time. I shall try some injector cleaner - in the fuel?
    When I am feeling brave enough I shall clean the egr.
    Any one - if the spanner light has not come on will any codes be stored?
    Jun 2009
    Middlesbrough
    Have the same sort of problem with mine, my of mine has given me the following information
    There is a field remedy (1957) from vauxhall for similar problems to yours.
    You should contact your local dealer to see if they have carried this out or not.
    Field Remedy: 1957
    Subject: Engine Y30DT, High Pressure Pump - Lack of power during acceleration
    Models: Engines: Option:
    Vectra-C 2003...2007,Signum 2003...2007 Y30DT| Z30DT,Y30DT| Z30DT
    Complaint: Engine lack of power during acceleration. During investigation with TECH2 a pressure drop between actual rail pressure and desired rail pressure is visible.
    Cause: Blocked suction control valve (SCV) within the high pressure pump.
    Production: Modified production process (earlier changing of manufacturing tools, improved cleanliness) implemented at supplier. Countermeasures were implemented with engine number 69692 (01.09.2006).
    Remedy:
    Before carrying out Technical Service Bulletin 1957 update ECU with modified software as of TIS 2000-DVD, version 76 (a modified software regarding high pressure diagnosis was implemented, improved DTC: P0093 detection).
    If the DTC still occurs refer to the following snapshots in datalist 2 "NOK I". The snapshot shows an increased fuel flow restriction within the fuel feed circuit.
    1: desired fuel pressure 2: actuel fuel pressure
    We recommend to disconnect the fuel lines from the tank to the filter, blow them by compressed air (in disconnected condition) and finally to replace the fuel filter assembly.
    The snapshot in datalist 2 "NOK II" shows a constant drop of actual fuel pressure and identified the suction control valves (SCV) failure.
    In case of an identified suction control valves (SCV) failure replace both suction control valves (SCV) of the high pressure pump as discribed below.
    Important: - During the complete procedure it is obligated to work in a clean environment. - Prevent contamination at SCV area. Small contaminations, which cannot be seen by eye, can cause major problems on engine performance. Particle size of 0,3 mm, can be already critical! - Do not use gloves. - Do not use SCV in case it has been dropped. - Make sure that pressure in the system is released before loosening the pressure connection pipe between pump and rail. - Disconnect battery after failure checking procedure. Wait for a few minutes before starting SCV replacement procedure in order to prevent any system action.
    Working Procedure:
    1. Remove high pressure pump
    - see working procedure "Replace high pressure pump", group "J", Service-Instruction Vectra-C/Signum. (Document-Number 01201498)
    2. Seal junctions of high pressure pump (Picture I)
    - attach plastic cap (5) to high pressure junction - attach 2x paper collar (3) with 4x seal ring (1, 4) and cap nuts (2) to fuel feed junction and fuel return junction
    Note: All junctions of high pressure pump should be closed right after removing each fuel line from still installed high pressure pump.
    3. Clean high pressure pump.
    Note: Brush off all dirt and rust using wire brush. Spray off dirt and rust using parts cleaner.
    Important: The area around the suction control valves has to be cleaned very thoroughly!
    4. Loosen suction control valve (1, Picture II)
    - remove 2x screw (2)
    5. Remove suction control valve (Picture III)
    - rotate suction control valve (1) to remove it from high pressure pump
    Note: Keep work area clean and make sure no contamination gets into and around suction control valve mounting hole.
    6. Prepare new suction control valve (Picture IV)
    - apply clean engine oil to both o-rings (1) of suction control valve
    7. Insert suction control valve (Picture V)
    - push suction control valve (1) into pump housing in direction of arrow using both hands
    Note: Several mm clearance (1) between suction control valve flange and pump head will remain. (Picture VI)
    8. Attach suction control valve
    - Install 2x screw by hand - tighten 2x screw with tool until suction control valve flushes with high pressure pump
    Note: Tighten each bolt alternately to prevent suction control valve inclination.
    - tighten 1st screw 13 Nm - tighten 2nd screw 13 Nm - re-tighten 1st screw 13 Nm
    9. Replace 2nd suction control valve accordingly.
    10. Remove seals from junctions of high pressure pump
    - remove plastic cap from high pressure junction - remove 2x paper collar with old seal rings and cap nuts from fuel feed junction and fuel return junction
    11. Install high pressure pump
    12. Conduct performance and leakage check
    - Conduct High pressure test by following TIS 2000 steps - Checking procedure (Tech2) - Non Guided Electronic System Diagnosis - B: Functional Group Test - B-004: ACTUATOR TEST - T-008: (for Z30DT T-009) Tester Display Fuel Leakage Test
    Spare-Parts: Part-No.: Catalogue-No.:
    Kit-suction control valve 98086740 8 19 348
    Labour Times: TC: Hours:
    U3 195 70 Install Kit-suction 92 5.9 control valve
    The costs for this repair will be covered during the normal warranty. The regular warranty procedure should be used for claiming Set-up-time.
    FunctionalGroup: J - Engine
    Complaint Group: 13 - No/Poor Function,20 - Poor Performance
    Trouble Code: None
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Wow, interesting stuff. My 3.0 has done this occasionally. Better get it in before the Network Q runs out.....
    Phil
  1. Juddering in 1.9 CDTi SRi 150
    By stuart-c in forum Engine & Drivetrain
    Last Post: 29th October 2010, 10:37
  2. Another juddering CDTI
    By neilrj in forum Engine & Drivetrain
    Last Post: 30th September 2010, 15:36
  3. CDTi 150 Juddering
    By SRiXPT in forum Engine & Drivetrain
    Last Post: 9th January 2010, 22:03
  4. 1.9 CDTI - Shuddering issues
    By phil g in forum Engine & Drivetrain
    Last Post: 21st September 2009, 20:02
  5. CDTI 150 SRI Shocks + Shuddering
    By terrym2002uk in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2008, 20:11
vectra 3.0 cdti fuel pressure regulator
signum 3.0 v6 cdti misfire
3.0 v6 cdti vectra cylinder 5 misfire
3.0 v6 cdti fuel pump removal
vauxhall 3.0 pump valves
insignia suction control valve
vectra c 3.0 cdti fuel pump
vectra v6 cdti misfire
vauxhall vectra c 3.0 cdti v6 scv valves
injectors 3.0 cdti change
https:www.vectra-c.comforumshowthread.php89265-3-0-cdti-shuddering-juddering
vauxhall vectra c estate 3.0 cdti fuel pump
vauxhall vectra 3l diesel fuel pump suction valves
where is the suction control valve on a vectra c 3.0cdti
vectra c 3.0 cdti judders no engine light
3.0 cdti hesitant acceleration site:www.vectra-c.com
