Results 1 to 10 of 11
Thread: EGR Valve on 1.9 CDTi 150
    Aug 2009
    Havant
    Default EGR Valve on 1.9 CDTi 150
    Hi Guys,
    Have been reading up and it would seem that a dodgy EGR valve may be the cause of my flat spot between 1 and 2k rpm
    I have seen on the how2 section that there is a how2clean the valve on a 2.0dti but only a how2replace on a 1.9CDTi.
    Can the valve be cleaned and put back on the 1.9 or do I have to go spend a fortune at VX on new bits and bobs?
    Ta!
    Bappy
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Yes, it can be cleaned which IMO is a 50/50 way of trying to sort it - I am sure there is a how2 for that on this forum.
    Aug 2009
    Havant
    Cheers Dan,
    What should I use? Electrical contact cleaner? Carb cleaner?
    Ta!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Take the EGR off - split the EGR at the allen key bolts - then submerge the mechanical side in brake fluid - then with a paint brush and rags with flat blade screwdriver get to work on cleaning it....
    You will also need to clean the inlet where the EGR sits - as that will be extremely caked up tooo.. Use a flat blade screwdriver with a rag over to clean out all the muck - then a paint brish with brakefluid on to finally clean up..
    Done a few now and it makes a huge difference if yours is very dirty.. Mine had only done 34K when I cleaned it and the amount of soot and muck in was increadible.!!
    A
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    I have definately read a how to on how to modify an EGR valve for a CDTI and it had a wonderful illustration of all the steps of removal/cleaning/modify. Got no idea where it is, I've had a quick look at the how 2 section but to no avail. Perhaps someone who can actually use the search feature of the site can find it?
    Bri.
    Fareham
    Trim : Elegance
    Okay found it here it a link to the thread.
    Perhaps an admin can move this to the how2 section if deemed as useful?
    How to Clean EGR Z19 EGR Valve
    Bri.
    Fareham
    Trim : Elegance
    Please find attached a PDF document of the How 2 to clean and modify the EGR for a Z19 CDTI engine. All credit for this How 2 goes to member 'jon7278'.
    Bri.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    See what I found on my car and how look after a quick cleaning !
    CristianTM.
    Fareham
    Trim : Elegance
    OMG!
    That sure was looking pretty gunked up? Was the EGR still working okay prior to your removal for cleaning?
    Bri.
    EGR working hard and not properly before.
    After cleaning the EGR, the engine began to consume less fuel and the engine began to be more nimble.
    CristianTM.
  1. Sri 120 cdti 8 or 16 valve
    By hamish123 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 22:07
  2. EGR Valve for CDTI 150
    Last Post: 19th August 2009, 15:13
  3. EGR valve 1.9 CDTI
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 23:09
