Thread: 04 2.2 DTi SRi - What code reader?
    Regular Member Phil MC's Avatar
    Kirkie
    Default 04 2.2 DTi SRi - What code reader?
    Hi there, can anyone recommend me a code reader for a 04 reg 1/2 canbus 2.2DTi SRi?
    My friend has an intermittent spanner light/limp mode, and we need to get a cheap code rader to diagnose the fault, so any help would be appreciated .
    Cheers.
    Also, if anyone can point me in the right direction to whereabouts the egr valve and boost sensor lives that'd be great too.
    Mileage : 000
    Does anyone have an answer to the above. As a mate of mine has the same problem.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi phil
    My Memo scanner U480 works perfect on my 03 signum 20 Dti.
    th egr valve is under the plastic engine cover,down the front of the engine,fastened to block with 2 bolts and has 2 coolant hoses to it.and the wiring harness.about an hours job to remove clean and refit (depending how dirty it is of course)
    Southampton
    check your vacuum tubes to the air flow meter as a pin hole in that was causing my spanner light moments
    (put your foot down & get the spanner light)
    ****** vx changed the boost pressure sensor & reccomended the air flow meter too - that would have been 300 quid
    the cure was to cut 2 in of vacuum tube off - cheaper
    its also worth cleaning the boost pressure sensor at the same time
    luck !
  1. Code reader
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2012, 22:05
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. Code Reader
    By Paddy in forum Engine & Drivetrain
    Last Post: 4th April 2011, 21:21
  4. Code reader
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 18:21
  5. code reader
    By stevie in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:48
