Thread: Bad vibrations
    Aug 2009
    london
    Default Bad vibrations
    HI ALL WONDERED IF ANYONE CAN HELP. RECENTLY BOUGHT A 2006 1.9 CDTI 120 VECTRA LIFE. SINCE CHANGING THE WHEELS FOR THE 17 INCH SRI WHEELS I HAVE NOTICED THAT WHEN DRIVING BETWEEN 40 AND 50 I CAN HEAR A HUMMING NOISE, VERY SIMILAR TO THE SOUND OF A SHOT WHEEL BEARING. HAD THEM CHECKED AND THEY ARE OK AND ALSO REPLACED THE FRONT TYRES DUE TO BEING WORN OUT. ALSO WHEN DRIVING ROUND SOFT BENDS I FEEL A SLIGHT VIBRATION THROUGH THE WHEEL MORE SO WHEN STEERING RIGHT. THANKS
    Jul 2009
    sussex
    have the tracking and wheel balancing checked/adjusted.
    Full Member Penfold101's Avatar
    Make sure they're torqued up properly as well - easiest check to do...
    Aug 2009
    london
    It has all been done twice , i work in a tyre shop, and done it all myself. That is what i thought it was. Might have to bite the bullet and drive it into the garage. Hopefully nothing major. Drives great other than that. Thanks anyway.
    Jul 2011
    Daventry
    Dodgy Tyre can cause a wheel bearing like sound, it does happen!
    Paul
    Ex Audi Sport Diesel Technologist
    What specification (brand, size, etc) of tyres are fitted?
    What tyre pressures are in use?
    Have the replacement alloys wheels been checked for true running?
    Where did you obtain the replacement wheels from?
    What type of machine do you have for balancing?
    What options do you have for weight setting? (ie 5g, 2.5g, or 1g)
    What type of weights are you using?
    Were the tyres aligned to the valves? (red dot)
    Where on the wheel are you fitting the weights? (white dot)
    It is quite unusual to get vibration through the steering wheel at less than 50mph if it is simply balancing
    I would therefore suggest arranging for the car to be placed on a ramp and drive the wheels to determine where the noise is coming from
    6 Post(s)
    Thread first penned in Aug 2009. One would hope the problem has been sorted by now, or he's sold the car.
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. Strange vibrations
    By BigWilko in forum Engine & Drivetrain
    Last Post: 13th March 2012, 20:28
  3. Vibrations?
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2011, 15:40
  4. Steering vibrations
    By Wilco in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2008, 09:16
  5. Vibrations!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 11:39
