Thread: Help needed fault code
    expat in mountain region of romania
    Default Help needed fault code
    been having my spanner light come up as i start car (goes off after a few seconds) vauxhall wanted £89 + vat to read code so bought a op com have plugged in and read codes, this is fault code i get
    P0070 - Ambient Air Temperature Sensor Malfunction
    (74) - Not present
    what is it and how do i cure it, have cleared the code for now
    thanks in advance, by way im in welling kent if any body needs to read trouble code
    Regular Member BoroDave74's Avatar
    Attleborough
    I was quoted £11 for the part and half an hours labour from an indy for this replacement which I meant to do last friday but had too many other things on...got a couple of weeks until I can get it in, but indy said not to worry!
    I think the part can be bought for less and at half an hours labour it can't be too difficult an install for anyone confident and competent.
    Melbourne, Australia
    Does your "outside air temperature" display show the correct temperature?
    Attleborough
    Its awfully close at anything over 20C but below that it's almost random. Mines being done as VX have suggested it as a resolution to my glow plug problem, rather than replace the ECU!
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    does anyone kow the part number for this as ive just had the same prob.
    is p0070 definatley the outside air temp sensor?
    as mine seems to be reading the outside temp ok.
    also is there a how 2 on how to change it?
    any help would be greatly appreciated
    It's located behind the front bumper. Clipped into the lower front grill.
    Sep 2009
    swansea
    Trim : Club
    had the fault code cleared & its gone for now. guess the sensor is dogey. why the hell should something thats not even related to the engine bring up a fault? Im guessing its VX out to make another quick buck.
    EVERYWHERE
    ECU needs to know correct air temp (density of air) in order to meter the fuelling correctly.
  1. Help needed please, fault code C1532
    By levy9 in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2012, 18:52
  2. fault code..help needed.please
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 16th July 2011, 12:26
  3. Fault code help needed please help thanks
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 29th March 2011, 18:37
  4. P0400 Fault code help needed PLease.
    By Nick1 in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  5. Help! - Fault Code Reader Needed!
    By irondan in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 21:39
