Thread: possible flat spot?
    jilava
    Default possible flat spot?
    Hi, I'm trying to figure out if this si normal operation and I need your opinions.
    I have a 2004 vec 150ps that takes about 2-3 secs to reach 2200 rpm from 1750 rpm and then starts to pull, probabily because the turbo kicks in. This is in 3rd gear, in 2nd it takes a bit less, about 2 secs.
    I did clean the egr valve and actuator guided by the how-to here on the forum (very helpful) about 2 months ago because the car had a hesitation problem around 2000rpm, and I did got rid of it. But I need some opinions on the possible flat spot problem.
    jilava
    The way I tested: keep the car at 1750 rpm in 3rd for a few seconds then boot it.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Maybe you need to check your swirl flaps / control bar... have a search on the forum, as there are a few threads that go into this in detail.
    jilava
    Dan, I did check with an OP_COM that has a swirl valve test, the rod seems OK, I posted 2 pics with the rod and position of the flaps in this thread http://www.vectra-c.com/forum/showth...ht=swirl+valve
    Does it look OK?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by andreitone View Post
    Does it look OK?
    Didn't see that mate, yeah that looks fine (very clean too) so it looks as though the Swirls are ok. Could be a faulty EGR, the clean doesn't always work mate.
    jilava
    could it have something to do with the boost sensor? I can try and clean it... rather than buy a new egr valve..., is there any way of knowing for sure if the egr is bad?
  1. Flat spot :(
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 19:06
  2. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  3. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  4. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  5. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
