Thread: Power Steering fluid
    Jul 2009
    Waterford
    Default Power Steering fluid
    Hi All
    I have a warning light on my car for the power steering.
    After a previous post it was suggested to me that the power steering fluid level could be low.
    I identified this as the problem, but what would cause the steering fluid level to drop. Is this common enough or could there be a greater problem somewhere. There is nearly 100,000 miles on the clock.
    Any suggestions would be great.
    As it's an awkward thing to check could be it's been missed a few times on service hth ....
    Jul 2009
    Waterford
    Hi Tadpole
    Yeah, it looks pretty awkward to get to. I will top it up and see if it leaks any further. It would be interesting to know if anyone else topped up the resevoir and had no further problems.
    Thanks for the reply.
    It could also be the level sensor it's self at fault.
    I am no expert one of the gang will give you more advice I am sure hth .......
    WGAF#5
    could be a leaky piston somewhere or a pipe seal going - was the level down by much?
    Jul 2009
    Waterford
    It was down just underneath the min mark on the bottle.
    I went up on a kirb about six months ago, I wonder if I damaged something then.
    Regular Member mishima's Avatar
    UK
    Quote Originally Posted by Dazbaz View Post
    Hi Tadpole
    Where about is this located? Cannot find in my manual or anywhere under bonnet! Cheers
    Nottinghamshire
    A few cars have the compact EHPS system and the reservoir is underneath the cooling system expansion tank.
    Most cars have the normal EHPS system which is located in front of the offside front wheel - if you open the bonnet and peer down the gap in front of the the air filter box (and behind the headlight unit), you should be able to see the filler cap - if you get the angle right.
    Jul 2009
    Waterford
    Quote Originally Posted by mishima View Post
    I have a 2003 GTS. The fluid bottle is under the headlight on the driver side. I was able to get at it by locking the stearing to the left, remove 3 screws under the wheel arch, pulling out the bumper. This gave me some room so I could put my hand up to the bottle cap and I was able to unscrew the fluid cap. It was very stiff and I had to give it a few goes. I was able to get a funnell down to the bottle and re-fill..
  1. Power steering fluid.........
    By Sway in forum Engine & Drivetrain
    Last Post: 18th December 2012, 20:06
  2. Power steering fluid
    By Friel in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2011, 23:29
  3. Power Steering Fluid
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 16:16
  4. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
  5. power steering fluid ??
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 17:14
