Thread: HIDs affecting radio reception!
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Default HIDs affecting radio reception!
    I have a problem - the radio reception in the SRi has never been that great, and definitely a lot worse than my previouse Vectra C. Now I've noticed that there's a lot more fuzz and crackle when I switch the HID lights on
    Any ideas what could be causing this? I did notice the aerial was all bent after I got the car so I replaced that with a standard replacement mast. If the mast has been bent could it have done some damage to the aerial base?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    I had the same with my HID kit when i put it in... ended up running seperate earths direct to the body of the car... new places rather than those already in use.. see how you get on as this cured mine
    Nov 2007
    North Lincolnshire
    Thanks for that. Where did you run the earths from, one of the wires coming out of the ballast resistor?
    oh well.. I tried..
    Instead of the earth from the bulb running to the ballast i run those to ground... just used and angle grinder to get a good clean earth, small pilot hole.. big self tapper and underseal over the lot
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I get this and it does my head in
  1. radio reception
    By fiend61 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2013, 10:28
  2. Radio reception
    By Graeme in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2010, 23:16
  3. CD 30 Radio No Reception on AM
    By Tomkid in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 14:44
  4. Bad radio reception fix?
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:36
  5. radio reception really bad
    By kev1983 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2008, 19:47
