Thread: screen wash bottle question
    Regular Member signum03's Avatar
    worthing
    confused screen wash bottle question
    hi, noticed when filling screenwash up it leaks out of the joint at neck, also noticed the neck can be removed, can you get another seal ? or is it something else???
    Full Member Big Sig's Avatar
    They all leak, just don't fill it up past the joint. The joint is to remove the filler neck to access the headlight. Also thats the main cause of the foglight on that side misting up, the water drips onto it from the bottle. hth
    worthing
    has vauxhall never heard of a water seal???? thanks
    There is a seal in there, a rubber O ring but the plastic neck just doesn't seal very well on it. Maybe grease it up to help with the seal? TBH its just better not to fill it up to the very top, its only a few 100ml's in the neck anyway
    Oct 2007
    Shropshire
    Mine used to leak, but when I fitted headlamp washers I got a new tank and i put vasaline around the joint when I put the new rubber grommet thing in..... Now you can fill it to the top and it stays there...
    Mine is an extremely tight fit and has never leaked
    I've even seen me check it a few days later and it still full to the top
    Well there is always one, mine has always leaked so it seems VX quality control isn't upto scratch!
    Regular Member old cruiser's Avatar
    slough
    No there's two!! lol , might doesn't leak either.
    Cheers Pete
  1. Help with screen wash
    By bighammerfan in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2009, 16:45
  2. a good bottle of car wash?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2008, 17:20
  3. Screen Wash
    By DeathStar in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 20:47
