Thread: Blown Bulb Warning...
    Jul 2009
    Midlands
    Default Blown Bulb Warning...
    Ive had the blown bulb warning light on my dash for some time now and can't seem to figure out which bulb is dead
    Is there any way that i can find out which one it is without driving myself mad and checking all the time?
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    It could be one of the brake lights as the car will use one of the other red rear lights as a sub until you replace it. The stop red light and the driving red light are next to each other can be hard to spot at first need someone to push all the lights and brack pedal and you stand at the back.
    Jul 2009
    tullow ireland
    when you start the engine and the system check is done it should say on the main display which bulb is gone, does this not show up ??
    Jul 2009
    Midlands
    Quote Originally Posted by big nath View Post
    I will have to try this tonight....
    Quote Originally Posted by Tullow_Vec View Post
    It's a 52 plate pre facelift model will this still apply?
    Jul 2009
    tullow ireland
    not sure mate, mine is a 08 reg, not sure if the older models have that system...hopefully one of the other lads will know...
    11 Post(s)
    The check control which tells you which individual light has failed (among other things) is only fitted on higher spec cars as standard. On lower spec all you get is just the one general warning bulb and it's up to you to look around the car to figure out which one has failed.
    Jul 2009
    Midlands
    Sorted thanks for the help guys
    Jan 2008
    Irthlingborough
    Which bulb had gone...
  1. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  2. Blown bulb warning light
    By Ant S in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 23:09
  3. Bulb blown warning ON, all bulbs ok??
    By bungle666 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2009, 02:39
  4. Blown Bulb Warning Help??
    By Jolly in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 00:15
  5. Blown bulb warning light on dash??
    By Genterz in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2008, 11:10
