Thread: Bored - Fitted Insignia wiper blades
    Jul 2009
    Default Bored - Fitted Insignia wiper blades
    I was in Vauxhall buying a touch-up pen the other day...Was supposed to be less than a fiver but ended up spending over a ton on bits and bobs for the car!!
    While i was in there a had a look over the insignia and liked the look of the wiper blades so bought a set for the vectra as the £3 tesco ones i was using looked naff and didn't work properly and generally were utter rubbish in comparison to a proper fitting std blade. The insignia ones are a std blade design but with a re-designed outer housing that looks more modern so i bought a set.
    The sizes are the same as the vectra and the fitting is very similar but i had to do a bit of modding to get them to fit.
    I had to cut about 6mm off the end of the hoop then squash the hoop to make it smaller. I was a bit weary about hacking away at the wiper arm but i'm glad i did, the fit is perfect and swapping blades out is really easy and they look and perform much better than previous blades i've tried.
    Heres a pic of them fitted, i'm going to take them off again and give them a paint up but what do you think?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Very nice mate, did you not consider just buying the Retro fit Vectra Flatblades from VX?
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    different but nice. how much are they?
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    To the OP
    Did you notice they were a touch shorter than the Vec ones.
    Vec-c wipers are 24" and 19", the Insignia wipers appear to be 1" shorter, at least mine were when I checked them. ie. 23" and 18"
    Dont suppose the small difference would matter much anyway.
    Jul 2009
    Hi guys.
    I didn't know Vauxhall did a retro-fit blade for the vectra but if they are anything like the tesco ones then I really didn't like them. With regard to the blade being shorter I'm not sure as I compared length to the tesco ones and not the original ones. If they are a little shorter then it's not noticeable so shouldn't be a problem I don't think.
    I think they cost about £10 each so not the cheapest wiper blades I'm afraid!
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by Cameron43 View Post
    To the OP
    Did you notice they were a touch shorter appear to be 1" shorter, Dont suppose the small difference would matter much anyway.
    My mrs said its a big difference
    Jul 2009
    Quote Originally Posted by spennny View Post
    Yeah but your 'blade' is only an inch long to begin with so another inch is going to double your size where as my blade is 23" so an extra inch isn't such a big deal. my misses couldn't tell the difference anyway...
  1. I need new wiper blades..
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 11:53
  2. i'm after some new wiper blades
    Last Post: 19th August 2009, 08:22
  3. Odd Wiper Blades ?
    By 900ss in forum Bodywork & Interior
    Last Post: 10th December 2008, 00:53
  4. Wiper Blades.......
    By signum_1.9 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2008, 14:05
  5. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
