Thread: any common areas to check for boot area rattles?
    Regular Member MCD's Avatar
    NE Manchester
    43 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default any common areas to check for boot area rattles?
    not a major one this! But seeing as everything is so solid, new & tight on my car, the boot rattle doing head it!
    1. Ive put card board under the foam thing that holds the jack etc.
    2. Ive padded around the space saver.
    3. The parcel shelf is fine, its not that.
    4. The boot is empty.
    5. The bumper clips, outside under car, where they clip to body work, ive silicone sealed this so no more rattle.
    But still, a rattle, going over bumps and uneven roads... could it be the boot lid itself (hatch?)
    Any ideas peeps?
    Mike
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    have u whipped the boot lid trim off to check there arnt any old clips or fixings floating about?
    Mileage : 000
    Could it be the actual boot catch,( the loop thing) that the boot lid catch hook into.
    I had to ( and many others) adjust this. You will need to undo it with a torx screwdriver or torx alen(type)key.
    EDIT. Have a read here too.
    http://www.vectra-c.com/forum/showpo...84&postcount=3
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by ed taylor View Post
    Mine was this, and the boot bump stop things needed adjusting too.... sorted it right out.
    NE Manchester
    43 Post(s)
    Engine : z20net
    Mileage : 80k
    Hmm, catch does sound like the noise im getting.... will have a look and report back!
    Mike
    Mileage : 000
    I bought the allen key type torx keys from halfrauds. They worked a treat on my estate. I don,t know what the catch looks like on the hatchback though.
    WGAF#5
    easy test for this is to drive on a bumpy road where the noise usually occurs - with the boot open -if no noise - it pointing in the right place
    if you still have the noise - then its something else im afraid
    Regular Member Largespanners's Avatar
    Jul 2009
    Swindon
    Mine had the same problem, i was convinced it was the boot itself, it turned out to be the 2 rubber "bungs" on inside of the boot (open the boot, turn round and look at the inside of the boot "door") those 2 rubber bungs were not contacting the plastic "mounts" on the actual parcel shelf.
    A bit of jiggery pokery and it was all sorted, not a rattle.
  1. did a common fault check on 1.9 cdti 150 16v heres the results!!!
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2013, 13:21
  2. Replies: 9
    Last Post: 6th January 2011, 20:18
  3. How can I check the area of potential house I want to buy?
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 8th January 2010, 18:09
  4. Boot area?
    By Messenger in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 21:19
  5. Boot Area Wiring
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2007, 18:17
vectra estate boot rattle
vectra c hatchback boot lid noise
Vectra C Hatch Rattle
vectra c boot hinge rattle
