Results 1 to 10 of 17
Thread: Am i right, CD70 will play MP3? how would i do this?
    Regular Member MCD's Avatar
    NE Manchester
    40 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Am i right, CD70 will play MP3? how would i do this?
    Hi Guys,
    AM i right in thinking MP3s can be played on the CD70? If thats the case, we have over 5 gig of songs on I-tunes on the PC.
    Could i write a CD with a good load of songs on it for the car? Please could someone idiot guide me, i.e what format from i-tunes etc please? Ive only ever written standard CDs from it...
    Mike
    Regular Member peppered's Avatar
    Jul 2009
    CD70 will only read mp3 files, so if your stuff on i-tunes is in mpeg 4 format you'll have to convert it to mp3 (using one of the hundreds of free converters you'll find online), then either dump all the mp3's onto the disc (which will give you a massive list of alphabetised tracks to choose from) or create folders on your disc first (with albulm names or artist names) and dump the mp3s into them.
    I think there's a how 2 somewhere for using WMP.
    Hope this helps!
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    Thanks that does help, alot!! Thankyou
    So, i need to find a conversion type software? Is that something stand alone i install on the PC, which opens the i-tune file and saves as MP3? Bit like windows media player?
    This sounds very exciting, the possibility of a huge amount of tracks in the car! I presume you simply drag and drop as may MP3s as possible to a data CD?
    Mike
    Jul 2009
    this is the converter I use:
    http://www.freewarefiles.com/Free-Ma...ram_39794.html
    you can get the program to drop converted files into a new folder then just copy the folder onto your disc.
    job done
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    Thankyou... again
    I will look at that when i get home! Is it easy to use & understand? Will i just have to point it at the i-tunes library or something, and it will creat the MP3s elsewhere?
    Mike
    Jul 2009
    unfortunately not - you drag the files into the program and it outputs them into a folder of your choice.
    you can drag multiples direct from itunes by selecting a load while holding CTRL and then set it on it's merry way.
    gimme a shout if you get stuck
    paul
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    Thanks Paul,
    I'll look at it tonight, i'm sure it will be straight forward, it looks it.... I will report back
    Mike
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    You can use iTunes to convert to MP3. I import all my cds in MP3 format.
    Also just to note I believe they recommend about 20 albums max per disc for optimum performance in the CD70.
    Jul 2009
    Quote Originally Posted by BigP View Post
    Can you??? Please tell me how it'd save me loads of time! All my CD's were imported as MPEG 4 - I had no idea i tunes would convert back!
    Apr 2006
    Quote Originally Posted by peppered View Post
    To select MP3 for all new imports go to the Edit tab and Preferences, then click Import Settings and select MP3 Encoder from the drop down list and click OK.
    To convert, select the tracks you want to change and go to the Edit tab and Advanced, Create MP3 Version. iTunes will then create a second MP3 version and list them un-highlighted and under the originals in your library. I normally then delete the original so that I don't keep getting mixed up.
    HTH
  1. can cd70 Sat Nav play MP3 cd's
    Last Post: 3rd November 2010, 23:26
  2. IO play with a CD70
    By jay w in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2010, 13:17
  3. Harman Kardon Drive And Play Fit Cd70?
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2008, 17:03
  4. IO Play Bluetooth installation into Vectra with CD70.
    By jlb777 in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 15:52
  5. just what format will the cd70 play?
    By PeterVV in forum General Chat
    Last Post: 1st May 2008, 07:59
can vauxhall vectra play mp3format
