Thread: Rear Wheel Bearings
    northampton
    Default Rear Wheel Bearings
    I have just been quoated £500 to do my rear wheel bearings, is this a good or bad price?
    thanks
    Mileage : 000
    I don,t know if Gary still has it but have a look here.
    http://www.vectra-c.com/forum/showpo...07&postcount=1
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I bought mine from a Vx specialist on Ebay, it cost me £65 for the part. Its not a big job for a mechanic to fit so expect to be charged for 1 hour, at an independent that will cost you about £40. So £500 is taking the wee. Admittedly mine was the front hub so was about £15 cheaper to buy but the rear is even easier to fix.
    northampton
    thanks for the info guys. The garage quoted me £60 labour which seems ok. Ill get it done before I sell it in a fortnight
    cheers!
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Got mine off ebay for £65 each and fitted them myself in an afternoon!
    market harborough
    well the parts are £59.00 + post so that means it must be a hell of a job ! im just wondering about doing the job myself ,
    Nov 2007
    North Lincolnshire
    Well it's a bit of an awkward job, but quite straightforward. Wheel and brake caliper off, then caliper bracket and disc off, then you have to get to the four bolts that hold the hub on from behind the hub. These bolts will be pretty tight - I had to use a breaker bar to undo them but there's barely any room to move the breaker bar when you're under there!! One of the bolts is quite obscured as well meaning you have to feel for it rather than have a good view of what you're doing.
    The second one is much easier to do once you've done the first.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by scottietlr View Post
    If it's VX parts they are approx 150 each so thats why the above price may be so high. £59 is that for rears as they are normally about 75 (rears cost more than fronts.)
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi it's a bit of a fiddly tight job but not two bad took me about 2 hours on my signum ,go for it bud you can do it for less than £100.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    How Much??? £500
    As you have heard from many already, that is a bit steep even if the garage you went to were to use genuine parts.
    I think you should either source the parts and just pay a garage labour or give it a go and tackle it yourself and save 100's pounds.
    bri.
  1. For Sale: Sri clocks, leather door cards, rear e/windows, wheel bearings
    By krazylegz in forum Parts for sale
    Last Post: 6th November 2012, 07:13
  2. rear wheel bearings
    By stickygreen in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2011, 20:19
  3. Wheel Bearings?
    By PedroMV6 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 16:56
  4. Wheel bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2008, 10:08
  5. Rear Wheel Bearings
    By kinger in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2006, 12:51
