View Poll Results: FLAT SPOT ON CDTI 150
Voters
365. You may not vote on this poll
  • Yes
    281 76.99%
  • No
    55 15.07%
  • Never paid any attention but will now!
    29 7.95%
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 122
Thread: Flat spot on CDTI 150-how many suffer from this-*POLL*
    Birmingham
    Default Flat spot on CDTI 150-how many suffer from this-*POLL*
    Im intrigued as to how many people suffer a flat spot on the CDTI 150, mine is between 1-2k rpm.
    So, please vote away and also please state anything you have done to successfully resolve this!
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    UK
    Mine suffers from this before the turbo spools up. I cleaned the egr which seemed to help but it is getting worse again after a couple of months so I might try replacing the egr.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Mine doesn't, but with a new EGR, Inlet Manifold and EGR, it shouldn't do either !!!
    Last edited by ed taylor; 4th August 2009 at 10:41. Reason: Edited due to by passing the swear filter.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    mine did but had my 3rd injector and wiring replaced spot on now
    Retford
    mine still does sometimes - not as bad since i had new egr, im trying to arrange a friend to strip down and clean the manifold so hopefully that will help
    has anyone noticed if the problem isnt as bad depending on the weather - i notices on rainy damp days mine runs a dream, i was told that the air is more moist and changes the airflow
    Birmingham
    Quote Originally Posted by Grimo72 View Post
    How do I know if the wiring on the 3rd injector is ??
    Is there a visual inspection!??!
    Bye bye Vec B
    - Hello Siggy!
    jilava
    sorry but I don't know what a flat spot is. Think I may have this, can someone explain? thanks
    Jul 2009
    sussex
    hesitation when accelerating.
    jilava
    ok, when i'm in 2nd gear and 1500 rpm, it doesn't matter how hard I push the trottle it picks up speed rather slow until 2000 rpm then really pulls. Is that a flat spot between 1500 and 2000?
    Birmingham
    Quote Originally Posted by andreitone View Post
    Thats the bad boy!!!
    Bye bye Vec B
    - Hello Siggy!
  1. CDTI 150 Dreaded flat spot HELP!!!
    By keets in forum Engine & Drivetrain
    Last Post: 19th October 2015, 09:26
  2. 1.9 cdti 120 poor mpg and flat spot at low revs
    By mattclayt in forum Engine & Drivetrain
    Last Post: 17th January 2013, 23:36
  3. CDTi-150 Flat Spot @ 1800rpm
    By Signum7060 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2012, 07:27
  4. Could this be the cause of 1.9 cdti 150 flat spot?
    By andreitone in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 18:00
  5. CDTI 150, more FLAT SPOT HELP please!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 7th May 2010, 23:28
vectra c flat spot 1800rpm
2013 astra 1.7 cdti sri engine flat spot
astra 1.9 cdti engine flat spot
1.9 cdti flat spot anove 2k
aatra 1.9 vdti sticky wastrgate
