Thread: graese the door hinges or not?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default graese the door hinges or not?
    I always did this until recently someone told me that VX do not recommend this any more?
    Seems odd to me, surely it can have no detrimental effects?
    Mileage : 000
    I don,t grease or oil mine. But if one started to "squeak" I would put some form of lubricant on it.
    Plymouth
    some people use copper grease on them...
    Mine squeak and i used grease.... But after 6 months it needs doing again and looks as if its collected all the crap....
    So prob copper grease for me.
    WGAF#5
    got copper grease on all of mine
    no problems here
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    I'm sure if I remember correctly, the Service book says, don't that lubricating front door hinges on the vectra-C is not necessary.
    Why, I don't know :
    Then again, if i had an issue, I would lube em up!!
    Oct 2007
    south wales
    Quote Originally Posted by John C S View Post
    Why, I don't know :
    why lube the back and not the front? wierd?
    May 2007
    Quote Originally Posted by PeterVV View Post
    I agree, weird.
    I will check later that I'm right!
    11 Post(s)
    Makes me laugh when a garage spray grease on the hinges. It doesn't do anything except make a mess. It doesn't penetrate into the hinge pin where the lubriaction would be of most benefit - it just sits on the outside of the hinges.
    It's purely a visual aid that the garage use to con you.
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    I wouldn't ever use copper grease to lubricate anything - it's to prevent things from seizing up, not as a general lubricant. I reckon on parts that are regularly moving copper grease will act like a mild grinding paste.
    Oct 2007
    south wales
    Quote Originally Posted by KTM Chris View Post
    I would have thought it would be too soft to act like a grinding paste? copper being softer than the steel pins?
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  3. Back Seat hinges - help !!!
    By vectrawife in forum Bodywork & Interior
    Last Post: 15th February 2009, 22:05
  4. Recycling Irmscher Door Sill Plates and Door Pillar Trims
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 19:08
