Results 1 to 2 of 2
Thread: vectra c front bearing and abs sensor
    Jun 2009
    WARWICKSHIRE
    Default vectra c front bearing and abs sensor
    mine has gone both warning lights are on the dash.. took it to vectra garage they told me it was front bearing and abs sensor gone they said they could order me one for £169 been looking on net and found this are these the same thing or a cheaper version...john
    http://www.lmfvauxhall.co.uk/store/home.php?cat=1444
    http://www.lmfvauxhall.co.uk/store/p...44&page=1&js=n
    Full Member spennny's Avatar
    Blantyre
    Have a look on EBAY mate, i got mine for £69 delivered, each side
    Have you cleaned the connections on the plugs, or checked they havent came loose, detached themselves from each other, worth a check mate,
    Have you checked for any play in the front wheels .....
    If you have the tools and need a hand, i dont mind helping also , did mine in just under 3 hrs with all the right tools
  1. Front wheel bearing sensor problem
    By rob123 in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2011, 23:31
  2. 2007 vectra front bearing hub
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2009, 21:33
  3. BRAKE LINING FRONT WEAR SENSOR Vauxhall VECTRA-C
    By Fedex in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2009, 14:09
vectra c front abs sensor
